audio services shut down after short time on arch-phosh
I was listening to music with audacious when after about five minutes my bluetooth headphones disconnected.
This also happened when the speaker was playing music, as the music simply turned off on the phone.
Audacious has a long-outstanding bug/feature request to inhibit suspend during playback.
https://redmine.audacious-media-player.org/issues/51
Until they add the feature you'll need a workaround like the ones in the mobian wiki. I'd suggest changing the .desktop file to use gnome-session-inhibit so that the phone won't suspend while audacious is running.
https://wiki.mobian-project.org/doku.php...pend-sleep
(12-17-2021, 11:04 AM)wibble Wrote: Audacious has a long-outstanding bug/feature request to inhibit suspend during  playback.
Hello, coming back to this problem, I've observed a disconnect from bluetooth after about five minutes of using the program mpv on an mp3 file.
I've also observed the problem occur both when I connect to the headphones through gnome-settings as well as bluetoothctl in terminal.
If you are using mpv, set up an alias to run 'gnome-session-inhibit --inhibit idle --inhibit suspend mpv <file>'
Alternatively follow instructions here: https://wiki.mobian-project.org/doku.php...-is-active
You can enable the systemd user service 'sguard' to prevent suspend while audio is playing. It works reliably. However most clients like Lollypop and GNOME Podcasts now inhibit suspend during playback themselves as well. I've found I don't need sguard anymore.
  stuck between phosh and plasma aular 0 231 02-27-2024, 05:55 PM
Last Post: aular
  Updating Arch Linux _radv_ 8 839 02-20-2024, 09:35 AM
Last Post: _radv_
  PinePhone AND/OR PinePhone Pro Arch Complete Install and Setup mikehenson 2 2,263 01-14-2024, 08:43 AM
Last Post: shifras
  How to install arch with FDE user641 3 792 01-11-2024, 10:18 PM
  How to find software app, on Arch Phosh? general_lee 5 1,954 10-15-2023, 10:12 PM
  Arch auto mount usb example Lazy_one 2 2,877 10-06-2023, 09:36 AM
Last Post: luppivega
  Arch with FDE user641 1 914 07-29-2023, 08:27 AM
Last Post: alpineduck
  No audio on calls after using wired headset Zebulon Walton 2 1,488 12-07-2022, 07:35 PM
  No keyboard on Arch Plasma when entering password on document Chief 0 853 12-03-2022, 08:35 PM
Last Post: Chief
  Curious About Arch Ferriah 2 2,149 11-07-2022, 04:38 PM
Last Post: Ferriah
