PWM fan control low power
Hey all!
I just got my first Rockpro64 this week, works great but i have a small problem:
The cpu fan is running very slow, it is connected to the pwm header and set at the max value of 255 in software, but it's still very slow (enough that it needs a push to start spinning on startup), but when i connect the ground wire of the fan directly to ground (effectively closing the circuit) it actually goes max speed. That tells me it could have enough power to spin faster but it doesn't, does anyone have the same problem or is able to help me figure this out?
note: I was planning on putting a second case fan connected to the same header, tried it and none of the fans spin (i can see they get a tiny bit of power but not enough to spin)
  RockPro64 automatically run after power recovery - my solution g2t 1 1,781 05-28-2026, 05:29 PM
  Rock Pro 64 Won't power on matthewmkr 9 8,863 04-29-2025, 12:57 PM
Last Post: matthewmkr
  power button not working Vista8720 0 3,428 05-07-2024, 11:26 PM
Last Post: Vista8720
  enble boot after power loss/restore dkebler 18 30,581 12-04-2023, 12:14 PM
Last Post: ok38
  PCIE interface power on too late Slark Xiao 0 3,012 11-29-2022, 11:56 PM
Last Post: Slark Xiao
  Automatic power on after power outage gechu 1 6,031 11-17-2022, 06:13 PM
Last Post: acj_
  After Power Loss feature working bdherouville 2 6,065 08-22-2022, 03:52 AM
Last Post: bdherouville
  ROCKPro64 sometimes doesn't Power On Pete Tandy 2 6,695 08-24-2021, 05:50 AM
Last Post: Pete Tandy
  Power Supply availability S265 2 7,063 06-07-2021, 09:20 PM
Last Post: S265
  control RP64 power on LMM 0 3,441 04-15-2021, 02:59 AM
Last Post: LMM
