ROCKPro64 sometimes doesn't Power On
A few months back I received my ROCKPro64 (4GB, v2.1) with aluminum case, RTC coin- battery holder, and 5A power supply. Everything is assembled and looks to run okay, most of the time. Except the board experiences an intermittent problem where the power button sometimes fails to start the machine, requiring several presses before any electrical activity. Other times it works like a charm. This can happen no matter which micro SD card is inserted, or even when I try a power-on with an empty reader. The button itself looks to be mechanically sound since the operating system never fails trap a shutdown press. I've since tried several different Linux distros on verified cards with no difference. Before giving my ROCKPro64 an unplanned early retirement, I was advised to register on the forums in case this has been solved. I've gone through the search facility but the hits didn't match my problem exactly.
welcome to the forum.
I have the same issue. But did not succeed to find a proper explanation. see this post : https://forum.pine64.org/showthread.php?...1#pid93571
(08-23-2021, 02:09 PM)LMM Wrote: Hi,
I have to push both power and reset.
But it only happens when I want to power on just after power off.
(08-23-2021, 02:09 PM)Hello, and thank you...At least it feels good knowing my copy isn't defective—relatively speaking. Since a few usersl have been asking about sundry power issues with their ROCKPro64, I'll assume it's a harmless but annoying quirk. Your reset and power suggestions seems to do the trick. Thanks again for your valuable pointers.LMM Wrote: Hi,
  RockPro64 automatically run after power recovery - my solution g2t 1 1,737 05-28-2026, 05:29 PM
  where to get debian 12 image for rockpro64? heocb 1 4,426 05-18-2025, 02:30 PM
Last Post: Dendrocalamus64
  Rock Pro 64 Won't power on matthewmkr 9 8,775 04-29-2025, 12:57 PM
Last Post: matthewmkr
  Use android on RockPro64 without a LCD screen ? john_nash 0 3,752 03-28-2025, 11:15 PM
Last Post: john_nash
  How to use ROCKPro64 PCI-e X4 to M.2/NGFF NVMe SSD Interface Card jykeith123 1 5,494 11-26-2024, 11:08 AM
  power button not working Vista8720 0 3,400 05-07-2024, 11:26 PM
Last Post: Vista8720
  Installing Wifi drive for the RockPro64 John45595 0 4,702 02-10-2024, 11:32 PM
Last Post: John45595
  enble boot after power loss/restore dkebler 18 30,443 12-04-2023, 12:14 PM
Last Post: ok38
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 6,203 09-17-2023, 12:00 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 4,888 08-14-2023, 07:55 AM
Last Post: kundanjha
