Screen stuck in Portrait mode.
Using the pre-installed Android 5.1.1 OS.  The Pine64 was working fine for the first few boots, but after I installed and opened an app from the Google Play store the screen rotated from landscape to portrait and has been stuck that way.
I Tried to power off + on, and tried uninstalling the app that seemingly caused the problem... Any other ideas?
(FYI - this was using the HDMI output to a tv screen)
I ran into this issue. I downloaded an app that rotated the screen back. I don't remember which app.
The "fix" for me was to go to go into the settings and reset the device.  I was careful to only install Netflix, YouTube and one game that plays in landscape mode after resetting a few times.
Not ideal, but at least it's not going into portrait mode.
I installed a app called "Screen Orientation" https://play.google.com/store/apps/detai...rientation This allowed me to set a widget to rotate when I pressed it. Hope this helps.
  stuck to sleep mode pinecil v2 lilibit 3 5,986 12-11-2023, 04:18 PM
Last Post: lilibit
  7" LCD Touch Screen Panel IanJames 0 3,273 04-01-2020, 04:40 PM
Last Post: IanJames
  User Screen Black After Changing Power Settings 0b51Gekko 2 7,596 07-03-2019, 07:53 AM
Last Post: 0b51Gekko
  Rock64 + 7" touch screen naviathan 2 7,192 09-28-2017, 09:01 AM
Last Post: naviathan
  7" Screen - Does it work with Debian abasel 1 5,849 07-26-2017, 05:44 AM
Last Post: pfeerick
  RESOLVED - LCD screen not working, HDMI does asuras 10 23,307 04-02-2017, 08:12 AM
Last Post: Luke
  HDMI-VGA adapter. Blank screen. trumad 10 26,466 03-05-2017, 03:17 AM
Last Post: pfeerick
  Does ubuntu img support the touch screen kingsing2 4 11,316 01-29-2017, 02:41 PM
Last Post: greglarious
  Stuck after getting connected to Internet Zettai 3 7,508 01-28-2017, 03:36 PM
Last Post: xalius
  Can't get past boot screen... (RESOLVED) codetheweb 13 33,910 01-19-2017, 08:43 AM
Last Post: Michaelrowe01
