Can I rollback to 9/10/2021 on Phosh using -Syyuu?
Hey guys, I messed up an update on my pinephone which is making calls not work.  I have monthly backups so its not a big deal but I know that some Arch based distros will let you rollback updates by using "pacman -Syyuu" and modifying a config file.  I was looking to basically do that with the Pinephone but the Manjaro Arm repos look a little different than I was expecting.  Any tips on how to do this?
I went ahead and just restored my backup and updated properly. Its all good. If there is a method of rolling back it would be good to know for the future.
I think you are referring to the Arch Linux Archive which can be used as a repo for a specific date. I'm not aware of something like that for Manjaro ARM. But you could just manually downgrade the updated packages to an earlier version cached in /var/cache/pacman/pkg/ with "sudo pacman -U /var/cache/pacman/pkg/[package]".
  Where Does Manjaro Phosh Store Its Custom Keystrokes? jakfish 0 851 04-25-2023, 09:49 AM
Last Post: jakfish
  Backup and Home Screen Tinkering on Phosh jakfish 0 903 02-24-2023, 12:56 PM
Last Post: jakfish
  MMS workaround for users with separate APN (works atleast on Manjaro Phosh) alaraajavamma 0 1,104 10-10-2022, 12:53 PM
Last Post: alaraajavamma
Question Running AnBox on Manjaro ARM w/ Phosh? danimations 2 2,573 09-05-2022, 03:42 PM
Last Post: nroth
Question Help installing Snaps on Pinephone running Manjaro ARM w/ Phosh danimations 2 1,966 04-07-2022, 06:02 AM
Last Post: danimations
  Manjaro Phosh Issues Csanderson0313 7 6,075 03-05-2022, 08:23 AM
Last Post: Csanderson0313
  No wifi with phosh image wave22 3 2,549 02-15-2022, 07:25 AM
Last Post: wave22
  How to remove Manjaro Phosh lock screen password? Avisando 4 4,039 10-28-2021, 04:20 AM
Last Post: Avisando
  How can I update Manjaro ARM w/ Phosh using Terminal? danimations 6 4,188 10-24-2021, 11:58 PM
  [phosh] boost pipewire volume beyond 100%? dcinoz 3 3,922 10-16-2021, 02:41 AM
Last Post: lacriz
