Running AnBox on Manjaro ARM w/ Phosh?
Question
I'm currently trying to install Snaps, with the objective of installing AnBox so that I can run a couple of Android apps on my Pinephone. I'm running Manjaro ARM w/ Phosh.
I'm keen to read about other users' experiences installing snaps and AnBox and any issues arising with apps used thereafter. I've hit an impasse installing Snaps, as I've just posted in another thread.
Thanks in advance.  Big Grin
For byte-sized tech and software tips check out my Danimations Digital Media tips channel on Youtube Big Grin
(04-06-2022, 11:38 PM)danimations Wrote: I'm currently trying to install Snaps, with the objective of installing AnBox so that I can run a couple of Android apps on my Pinephone. I'm running Manjaro ARM w/ Phosh.
how about trying Waydroid instead. Yo can install in with pamac and it does Android quite well.
Waydroid is [still not supported](https://forum.pine64.org/showthread.php?tid=16216) on the Pinephone Pro so you'll have to use it with [a fix to disable hardware acceleration](https://forum.pine64.org/showthread.php?tid=16022) along with possibly other tweaks. Opening after a stock install reveals a glitchy mess.
  Manjaro: Settings doesnt open nbh 0 590 09-24-2023, 05:25 PM
Last Post: nbh
  Can't get ring on Manjaro Pine Phone thorensjubilee 12 3,496 06-09-2023, 04:40 AM
Last Post: thorensjubilee
  Is Manjaro ARM a Rolling Release? jojuma 4 1,603 05-10-2023, 09:27 PM
  Where Does Manjaro Phosh Store Its Custom Keystrokes? jakfish 0 807 04-25-2023, 09:49 AM
Last Post: jakfish
Exclamation My short experience with Manjaro Plasma Mobile anonymous 10 4,759 03-02-2023, 07:25 PM
  Backup and Home Screen Tinkering on Phosh jakfish 0 860 02-24-2023, 12:56 PM
Last Post: jakfish
  Can't install Manjaro thorensjubilee 1 1,027 02-09-2023, 08:17 AM
  Manjaro plasma-mobile Beta 13 Uturn 13 4,902 01-25-2023, 04:15 PM
  Manjaro Plasma busted Chief 2 1,580 11-22-2022, 05:00 PM
Last Post: Chief
  MMS workaround for users with separate APN (works atleast on Manjaro Phosh) alaraajavamma 0 1,067 10-10-2022, 12:53 PM
Last Post: alaraajavamma
