USB WIFI Dongle Support
Is there going to be support for external USB wifi dongles and if so would you be able to supply a list of compatible ones?
(01-20-2016, 04:58 AM)InCognito Wrote: Is there going to be support for external USB wifi dongles and if so would you be able to supply a list of compatible ones?
There is no plan to support external USB Wifi dongle.
It should be possible to create new community images with drivers for external USB WiFi dongles.
It is up to the community to make those images.
The rule of thumb is that if that USB WiFi dongle works on your Linux desktop, it will be possible to get it to work on the Pine64 (with suitable community image).
(01-20-2016, 11:18 AM)taros Wrote: It should be possible to create new community images with drivers for external USB WiFi dongles.
This is possible for Linux OS.
Question RGB LED Matrix support? foxnox 1 5,185 12-29-2017, 06:52 PM
Last Post: psychedup
  Dallas 1-Wire Support ItsDave 31 50,009 12-27-2016, 08:30 PM
Last Post: ed_mann
  RaZberry Module (z-wave) need support to get it working! Luxus 13 23,859 11-03-2016, 02:04 AM
Last Post: Luxus
Wink Multiple wifi remotes klafbang 11 17,125 09-12-2016, 08:06 AM
Last Post: Steamkraft
  Wifi/Bluetooth module riahim 7 11,418 07-05-2016, 10:19 PM
Last Post: Ghost
  wifi cast hazerty 1 5,007 12-24-2015, 05:50 PM
