RGB LED Matrix support?
Question
Is the following LED panel compatible with the Pine A64+ 2 GB?
https://www.dfrobot.com/product-1644.html
That looks like it uses 5V logic, and the pine64 uses 3.3V, so you would need some sort of level shifters to use it safely. Besides that it ought to work, but keep in mind you will have to wire it up to the GPIO pins yourself (their connector probably won't work), and you would have to write your own driver for it.
  Dallas 1-Wire Support ItsDave 31 60,546 12-27-2016, 08:30 PM
Last Post: ed_mann
  RaZberry Module (z-wave) need support to get it working! Luxus 13 28,619 11-03-2016, 02:04 AM
Last Post: Luxus
  USB WIFI Dongle Support InCognito 3 9,952 01-20-2016, 11:27 AM
