Thunderbird - anyone using it on Mobian?
Is anyone using Thunderbird on Mobian?
I'd like to copy across my profile from a PC and wondering whether it might work.
Also wondering where to put the profile under Linux.
Tnx
Thunderbird keeps everything in a hidden directory called .thunderbird in your home directory, that is "~/.thunderbird", copy it in your phone's home directory and it should work
Great. Thanks.
  pinephone-support package not upgradable on Mobian fhireman 5 9,196 02-28-2026, 05:49 PM
Last Post: baptx
Exclamation No wIfI after Mobian update crakabeats 5 8,795 02-28-2026, 04:18 PM
Last Post: baptx
  What is wrong with the Mobian signature key? Mahgue 0 1,802 11-08-2025, 05:13 AM
Last Post: Mahgue
  Clamares password needed with new Mobian installation fauvetan 1 3,413 06-26-2025, 03:00 AM
Last Post: merom
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 15,362 12-04-2023, 02:14 AM
Last Post: Peter Gamma
  Mobian PIN changed after update! Mwo87 21 35,497 12-02-2023, 11:53 PM
Last Post: Karrenbrady
  Cellular Data, Mobian - "No WWAN Adapter Found" justneedsomedatathanks 3 9,030 05-25-2023, 09:03 PM
Last Post: justneedsomedatathanks
  No sound after Mobian upgrade arbocenc 1 3,209 11-28-2022, 11:02 AM
Last Post: arbocenc
  PinePhone running Mobian - Malware extraction? names_fold 1 3,763 01-24-2022, 12:00 PM
  Mobian updates for phosh steves 2 6,108 01-17-2022, 02:18 AM
Last Post: bcnaz
