Axolotl on Pinephone
I'm using Manjaro with Phosh and I installed the Flatpak of Axolotl, the Signal client. It seemed to install fine but it fails to open when I press the icon. When I tried running it via cl I got the following error output but I'm not sure what it means exactly. Is there any way to fix this? Thanks!
DEBU[0000] [axolotl] NewDataStore
INFO[0000] [axolotl] Starting axolotl ws
DEBU[0000] [axolotl] Using axolotl-web path /app/bin/axolotl-web/dist DEBU[0000] [axolotl] NewDataStore finished
INFO[0000] [axolotl] Loading Chats
INFO[0000] [axolotl] Db setup finished
DEBU[0000] [axolotl] Start Session after Decryption
DEBU[0000] [axolotl] starting Signal connection
DEBU[0000] [axolotl] config path: /home/manjaro/.config/textsecure.nanuc DEBU[2021/07/20 13:24:41] [axoltol] Opening Dialog: getPhoneNumber
DEBU[2021/07/20 13:24:41] [axolotl-ws] send request getPhoneNumber
ERRO[0022] '/home/manjaro/.config/textsecure.nanuc/electron/vendor/electron-linux-arm64/electron' exited with code: -1 INFO[0022] astikit: stopping worker...
DEBU[2021/07/20 13:25:04] [axolotl-electron] main: creating window failed: context canceled DEBU[2021/07/20 13:25:04] [axolotl-electron] open dev tools false
INFO[0022] astikit: worker is now waiting...
[manjaro@manjaro-arm ~]$
(07-25-2021, 11:36 PM)CarmeloLabadie Wrote: I'm using Manjaro with Phosh and I installed the Flatpak of Axolotl, the Signal client. It seemed to install fine but it fails to open when I press the icon. When I tried running it via cl I got the following error output but I'm not sure what it means exactly. Is there any way to fix this? Thanks!
It means Electron is not working which is used for the default frontend of Axolotl. You could try to start Axolotl in server mode ("axolotl -e server") and then connect to it with a browser (via 127.0.0.1 port 9080). But there is also a Debian package for Axolotl you could try and a lot more information in this thread, maybe you find a solution there.
Edit: This seems to be your problem too, check the following posts for a solution (remove everything from Axolotl and (re)install the .deb package).
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 21 2,167 8 hours ago
Last Post: anonymous
  unofficial kali linux for pinephone help needed pinesmell 5 3,666 01-08-2024, 02:50 PM
Last Post: ERPlegend
  Axolotl on PinePhone / Mobian arno_nuehm 219 166,463 03-26-2023, 01:49 AM
Last Post: shulamy
  PinePhone won't boot after software update jb2000 2 1,347 03-17-2023, 07:26 AM
Wink Pinephone lost graphic during mobian system upgrade cmpin 4 2,211 03-01-2023, 04:45 PM
  Battery problem with a Pinephone keyboard and Mobian elode 2 2,213 12-22-2022, 07:10 PM
Last Post: acid andy
  Sending Pinephone SMS from Desktop biketool 5 2,953 09-13-2022, 01:46 PM
  How to get Pinetime working with Pinephone arkadione 12 7,342 08-28-2022, 12:30 PM
Last Post: Fish
  PP Keyboard doesn't charge Pinephone (Mobian) jojuma 1 1,246 08-06-2022, 01:10 AM
Last Post: elode
  cryptocurrency on mobian/pinephone biketool 31 37,507 06-15-2022, 03:14 PM
Last Post: Hobbes42
