jumpdrive software might be faulty (or my pinephone hardware)
this is quite preliminary view and when i get more information, i clarify what's going on. still it's headzup issue for some. i have pinephone hardware 1.2a.
i noticed that using jumdrive software, both 0.7 and 0.8, computer only saw 6GB intenal storage instead of 32GB. using telnet, then size was correct. this meant that flashing was not succesful.
https://github.com/dreemurrs-embedded/Ju...e/releases
i ended up installing o.s. to the memory card and after that i installed to the internal memory.
serious disclaimer, my pinephone could be faulty by hardware because i have some issues with gps as well.
(07-19-2021, 06:55 AM)zetabeta Wrote: jumpdrive software might be faulty (or my pinephone hardware)
probably false alarm
seems to be that i have problem with my computer, in this case debian. for some reason 32GiB usb memories function as 6.79GiB in size. happened also with other usb memory. actually usb adapter for sd card.
it could also be the ISO, double check it to make sure it's not a 6GiB iSO
old fashion reboot and computer showed sizes correctly. so, i assume something was messy with linux kernel when attaching and detaching usb mems.
i don't have optical drive (actually i have usb based optical drive but rarely used). if bug repeats, i check is it optimal image or something else weird.
side note: i use "lsblk" , "fdisk -l" and others to show sizes. in this case i meant whole disk/mem size and not partition sizes.
  Pinephone software Csanderson0313 3 441 07-10-2026, 02:21 PM
  PinePhone Game Thread PixelPaintbrush 31 81,938 06-11-2026, 02:50 PM
Last Post: elinkser
  How can I record video on a Pinephone? kk22 23 23,216 03-25-2026, 12:55 PM
Last Post: baptx
  Pinephone visibly losing power while plugged in Hiraghm 8 7,431 03-09-2026, 07:51 PM
Last Post: Tia Vaughan
  pinephone-support package not upgradable on Mobian fhireman 5 7,490 02-28-2026, 05:49 PM
Last Post: baptx
  beep - playing PCM samples on PinePhone? WhiteHexagon 0 1,160 12-04-2025, 08:07 AM
Last Post: WhiteHexagon
Star Selling my Pinephone Pro Explorer Edition zheyon 2 4,485 12-01-2025, 10:25 AM
  PinePhone sensors - Gyroscope power WhiteHexagon 3 2,063 11-30-2025, 08:07 AM
  Light Sensor / Proximity Sensor on PinePhone? WhiteHexagon 1 1,588 11-18-2025, 03:07 PM
  Pinephone boot. Richy_T 8 7,270 10-21-2025, 12:12 PM
Last Post: Richy_T
