U-Boot, video console, and visual artifacts
I saw this funny thing, when playing with my own UEFI OS Loader on a RK3399 board. But it was on the HDMI interface.
I break uboot flow manually and command it to load and jump into my UEFI OSL (fatload, bootefi). My OSL shows things as expected, no artifacts, then I press a key and my unfinished yet OSL returns to uboot, then I type bootdefault, forgot the exact command name and uboot types reporting about loading linux, and right after jump into linux, this stripy image appears on the screen. definitely looks like linux overwriting the GOP framebuffer.
ANT - my hobby OS for x86 and ARM.
(07-08-2021, 03:09 PM)z4v4l Wrote: right after jump into linux, this stripy image appears on the screen. definitely looks like linux overwriting the GOP framebuffer.
I agree that it looks like the framebuffer is overwritten and filled with garbage, but I think that's just one part of the mix that causes this issue.
In one of the attempts to fix this issue, I've modified the U-Boot drivers for the RK3399 eDP output and the RK3399 VOP to get removed and turn the hardware off before booting into the Linux kernel, which made the "second plaid" (the one when the kernel starts) pattern to disappear, but also caused my PineBook Pro to lock up while attempting to boot the kernel.  I still need to debug that.
we previously talked on IRC about how I don't get a display. I use Gentoo with Manjaro kernel 5.11.16 and that works, but using even vanilla 5.11.16 fails to display anything. I found that using I have to use two Manjaro patches to get display working and they are still present in Manjaro's repo:
https://gitlab.manjaro.org/manjaro-arm/p...hack.patch
https://gitlab.manjaro.org/manjaro-arm/p...tcpm.patch
I'm not sure how the screen behaves on 5.13, my experience is with 5.11.16. I'm now planning to upgrade to 5.13.
I use uboot 2021.07.
Display works on 5.13.2 with those patches.
I also see the green plaid pattern, but for me it replaces the text instead of being overlaid on it.
I investigated the scary-looking message about a bad SPI CRC checksum; it turns out to be unrelated and harmless. It just means that there isn't any U-Boot configuration stored in the SPI flash. Unfortunately I don't think it can be gotten rid of except by moving the entire bootloader into the SPI, or by code changes to U-Boot. See https://lists.denx.de/pipermail/u-boot/2...53338.html (no response, alas)
My apologies for the delayed response.
(07-17-2021, 08:01 AM)pkubaj Wrote: we previously talked on IRC about how I don't get a display. I use Gentoo with Manjaro kernel 5.11.16 and that works, but using even vanilla 5.11.16 fails to display anything. I found that using I have to use two Manjaro patches to get display working and they are still present in Manjaro's repo:
I'm not sure how the screen behaves on 5.13, my experience is with 5.11.16. I'm now planning to upgrade to 5.13. I use uboot 2021.07.
Thank you very much for providing this feedback!  I've had a rather detailed look at those two patches, but I'm still not exactly sure why are they required to make the video output work.  I'll have another look at that.
(07-19-2021, 07:22 AM)zackw Wrote: I investigated the scary-looking message about a bad SPI CRC checksum; it turns out to be unrelated and harmless.  It just means that there isn't any U-Boot configuration stored in the SPI flash.  Unfortunately I don't think it can be gotten rid of except by moving the entire bootloader into the SPI, or by code changes to U-Boot. See https://lists.denx.de/pipermail/u-boot/2...53338.html (no response, alas)
Right, that's a rather benign error message, as I've already explained in one of my earlier posts.
Hi!
What is the status of those patches ?
Kind regards,
Xavier Miller.
(03-01-2022, 03:29 AM)alchemist Wrote: Hi!
These patches are not required for working display panel on Pinebook Pro since kernel 5.15.5. They are required to get external display over USB-C working though. The issue before 5.15.5 was that external display was mandatory for proper display initialization but since it's not implemented it caused entire display subsystem to fail. So basically panel display did not function because external display did not function. With below upstream fix, external display was disabled in dts giving panel display a chance to initialize successfully:
https://git.kernel.org/pub/scm/linux/ker...7c9fbfa3b1
OK thank you!
Kind regards,
Xavier Miller.
Bump Smile
Have the same with Kali (5.16.18 kernel). Not sure if it was caused by armbian & an update function in armbian-config or if it was included in Kali. It's an artifacts galore during bootup. I'm not even it does reboots...
  upgrading u-boot--what version? where to get it? bsammon 5 125 7 hours ago
Last Post: dachalife
  uboot wont boot to SD card after upgrade jbradley419 7 1,026 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 335 01-16-2024, 09:17 AM
Last Post: jbradley419
  Video Editing Is Possible On The PineBook Pro! ImmyChan 10 7,841 12-17-2023, 09:29 PM
Last Post: insideau786
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,437 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 796 12-13-2023, 08:17 PM
Last Post: trillobite
  Various freezes during boot & while running several Linux distros - hardware error? donuts 1 654 11-22-2023, 11:47 AM
Last Post: fxc
  Cannot boot to Kali SD card after uboot upgrade jbradley419 4 1,295 09-19-2023, 08:48 AM
  Does latest Tow-Boot install/work correctly for everyone? tophneal 4 2,023 08-03-2023, 03:30 PM
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 838 07-13-2023, 01:50 PM
Last Post: PaulQ
