sms app is outside of screen cant send sms right now.. quick fix?
Hi. i can't send sms right now..the app is too far right outside of the screen, how can i fix it quick? Need to send a text! thanks!
How do i fix popups, buttons that are outside of the screen sometimes? I love the phone.. But i need to come up with a universal solution to this. An universal solution so all apps fit the phone screen maybe? Thanks
i searched:
https://wiki.mobian-project.org/doku.php...ale-to-fit
What's the scale-to-fit???
5 of 5 Points, fully optimized ? I would say 4 out of 5? Because of the scale..
Edit: I fixed not seeing the button with unlocking the screen rotation and rotating the picture.
(06-01-2021, 12:28 PM)temp0rary Wrote: Hi. i can't send sms right now..the app is too far right outside of the screen, how can i fix it quick? Need to send a text! thanks!
i searched:
I experienced this issue as well with yesterday install of 20210517 image. All I had to do was update & dist-upgrade and problem disappeared. Sometimes I see some hiccups in scaling but all can be solved by rotating to wide and back.
Scale-to-fit is fix for apps not optimized for mobile screen, for example Evolution (You still need it to import contacts). It is simple command you run in terminal and app tries to fit PinePhone screen (not successfull everytime, but it works somehow). However I had to use it only for contacts import. From then no need to do scale-to-fit for me.
Ok, thanks for the answer.. yeah. It's small issues.. Overall everything works good in my opinion. It's a working phone. It should be more beefy in the future though when it comes to capacity/specs.. Other then that.. Sweet phone!
  Screen auto-rotation sensitivity mdk 0 274 12-26-2023, 06:08 AM
Last Post: mdk
  Screen stay black unless power key pressed short freelectro 0 657 06-24-2023, 01:55 PM
Last Post: freelectro
  Unsuspend → Black screen mdk 15 5,220 06-22-2023, 11:20 AM
Last Post: Melechtna
  Lock screen question: always squeekboard tuxcall 1 1,233 02-02-2023, 08:51 PM
Last Post: Haibara23
  [solved] Black screen at boot time mdk 0 1,017 01-13-2023, 03:33 AM
Last Post: mdk
  Unable to send messages with chatty user641 0 778 09-07-2022, 04:35 AM
Last Post: user641
  how to split screen? andrew907 2 1,538 08-08-2022, 09:38 AM
Last Post: andrew907
  Proximity sensor is oversensitive (was "Screen blanks when making call") treebeard 5 2,820 08-02-2022, 03:16 PM
Last Post: treebeard
  on screen keyboard woes vusra 1 1,253 07-18-2022, 03:29 AM
Last Post: vusra
  Giving certain audio apps priority on the lock screen and pulldown 3x5co 0 861 07-17-2022, 10:34 AM
Last Post: 3x5co
