Advice on building a simple computer…
Hello Pine64 community!
Can some of you please suggest a website and/or book for building a laptop or tower from scratch?
Mini-thanks
@SeeMossRun This is a very open-ended question. Please be more specific.
(05-24-2021, 12:09 AM)barray Wrote: @SeeMossRun This is a very open-ended question. Please be more specific.
Perhaps this community is too advanced.  The question is straight-forward.  The OP seeks resources and instructions for assembling a computer from component parts.  The poster has no such experience . . .
It is still a very open ended question. Yes, a guide could be recommended - but for what type of computer? A gaming rig? Photo editing? Web browsing and office tasks? What budget?
I would suggest you do a search on YouTube for "How To Build A PC" - you can add the type as another keyword if you have a specific need - and you will find an endless number of videos from the likes of 'Linus Tech Tips', 'IGN' , 'JayzTwoCents', etc, etc... which will walk you through assembly. Some will also explain why the varrious parts were selected.
As far as building a laptop from scratch, that doesn't really happen... you can customise one from a curated list of options, but I'm not aware of being actually able to *build* one.
The question is not simple, depending on what you are asking. For example:
* If you're looking to build a normal PC, LinuxTechTips could be a good starting point: https://www.youtube.com/playlist?list=PL...4578XfgJm_
* If you're looking for some 'DIY' laptop but don't want to build your own hardware, checkout something like a Pi-Top: https://www.pi-top.com/products/pi-top-3
* If you're looking for an open source laptop that you can do your own hacking to, checkout the Pinebook Pro: https://www.pine64.org/pinebook-pro/
* If you're looking to build a laptop from scratch, you're limited to whatever guides you can find online and you will definitely need to do some hardware yourself.
It's not clear what your goal is, so it's not obvious whether you are asking your question in the right place.
  Im thinking of building a Pine64 cluster Theirat1991 1 610 01-12-2024, 03:31 AM
  Which Pine64 single-board computer has NO on-board wireless modules? peteressive 2 1,308 03-10-2023, 03:35 PM
Last Post: peteressive
  Building Kernel App for fast GPIO nimblemotors 0 1,373 05-21-2021, 11:56 PM
Last Post: nimblemotors
  Simple Unixy mistakes that will ruin your day KC9UDX 7 6,729 02-01-2021, 10:47 PM
Question Micro computer module Computer semi-expert 7 8,433 09-29-2020, 04:52 PM
  What are the chances of getting a pine64 mini computer Omnios 4 5,593 09-06-2020, 04:04 AM
Last Post: SpoofyKid
  Would it be possible to have a pine C-64 mini arm computer project board. Omnios 1 3,273 03-27-2020, 06:00 AM
Last Post: pljanson
  Single board computer for coding classes (Python / EduBlocks) pawlinski 4 5,558 03-20-2020, 10:49 AM
Last Post: ab1jx
  Anyone remember this "super computer" SBC from 10 rears ago? KNERD 0 2,151 11-12-2019, 10:52 PM
Last Post: KNERD
Question Does the Rock64 single board computer (1, 2 or 4 GB ram) have a PCie slot? IP_Proxy 5 6,681 04-29-2019, 08:19 PM
