Does the Rock64 single board computer (1, 2 or 4 GB ram) have a PCie slot?
Question
Hello everyone I'm thinking of getting a Rock64 single board computer and I'm wondering if it has any type of PCie slot (slot for external gpu) because apparently it's GPU is not that good and I'm getting the 4gb variant of the Rock64 SBC because I want to use it as a mini pc when I'm out and about so please can someone answer?
--Thanks in advance
Prox
The RockRro64 has PCIe, but you'd need drivers for the GPU and I do not think anyone has gotten eGPU working on the board. The Rock64 doesn't have a PCIe interface.
Then is it possible to get a PCie slot connectes to the usb 3.0 or gpio pins?
There are external GPU enclosures compatible with Apple's Lightning connectors, but none yet for stock USB of any grade. Also, I think you'll have a hard time finding good drivers for ARM if you're thinking Nvidea or AMD...
There are good drivers for the Mali and it is plenty of graphic power for anything the processor can run.
That said, a more modern Tegra or similar would be nice, but the chip alone would nearly double the price of the board.
Wich PCie SATA controller to make a NextCloud server work better?
Does this around 50 USD model link would work well?
https://www.amazon.es/dp/B07MPG1DKD?tag=...f=aa_scomp
(04-26-2019, 06:47 AM)mitcoes Wrote: Wich PCie SATA controller to make a NextCloud server work better?
There are developers in ROCK64 IRC tested Marvel SATA chipset and claimed work.
  A post about a Pine-64 Wi-Fi ethernet router project board and enclosure? Omnios 1 597 09-21-2023, 07:52 AM
  Is it possible to use Pine-64 board as a Mini PC such as BeeLink? Omnios 1 784 08-30-2023, 04:23 PM
  Which Pine64 single-board computer has NO on-board wireless modules? peteressive 2 1,290 03-10-2023, 03:35 PM
Last Post: peteressive
  Article: Automated Testing of Apache NuttX RTOS on PineDio Stack BL604 RISC-V Board lupyuen 0 899 05-21-2022, 09:36 PM
Last Post: lupyuen
  Article: The Things Network on PineDio Stack BL604 RISC-V Board lupyuen 0 1,303 09-20-2021, 08:40 PM
Last Post: lupyuen
  Article: LoRaWAN on PineDio Stack BL604 RISC-V Board lupyuen 0 1,283 09-15-2021, 09:27 PM
Last Post: lupyuen
  Article: PineDio Stack BL604 RISC-V Board: Testing The Prototype lupyuen 2 2,448 08-29-2021, 10:19 AM
Last Post: lupyuen
  Advice on building a simple computer… SeeMossRun 4 3,471 05-24-2021, 05:25 PM
Last Post: barray
  Article: uLisp and Blockly on PineCone BL602 RISC-V Board lupyuen 3 3,662 05-21-2021, 11:58 PM
Last Post: nimblemotors
  Article: PineCone BL602 RISC-V Board Receives LoRa Packets lupyuen 0 1,556 04-04-2021, 03:53 AM
Last Post: lupyuen
