Im thinking of building a Pine64 cluster
So Im thinking of building a Pine64 cluster for a homelab over a Pi for a couple reasons, also being able to order more than one of the same type.
Their website sells USB to barrel power adapters awesome! But I need a power strip that can output 5V 3A for at least four USB ports.
I am not honestly that familiar with power usage and finding pieces but I see a lot of 2.4Amps with a max total of 12Amps. Out of a USB power strip. Is 3A really just 2.4?192.168.0.1 routerlogin 192.168.l.l
2.4A is already over the design spec for USB-A if my memory is correct.
If you need 4x3A, you may be better off "homebrewing" something with a 5V15A regulated supply, 4 3A fuses and 4 "barrel plug" cables. Otherwise just use 4 "barrel plug" wall warts. There's no real advantage in using USB for this, IMHO.
USB-C is different, and was actually designed with high current in mind. But I have no idea what's available for that, or if it even makes sense to use it, because a lot of USB-C power is delivered at higher than 5V. I'm pretty sure none of the Pine devices can take advantage of this.
:wq
[ SRA accepts you ]
  Link USB power strips for a cluster? shanefe 1 233 04-02-2024, 11:11 PM
Last Post: evilbunny
  Unable to connect to Pine64 IRC channel due to certificate error? Must-Borrow 1 410 03-10-2024, 02:43 PM
Last Post: Must-Borrow
  Forum Recommendations for Pine64 support? backwoodstech2 0 411 02-04-2024, 07:12 PM
Last Post: backwoodstech2
  PINE64 EU / Disappointment yoriel79 1 917 12-24-2023, 11:00 PM
Last Post: meekice
  How is it going Pine64.org? Corfromleuven 2 1,084 12-23-2023, 08:15 PM
Last Post: polinkuer12
  Registering my 'nick' on Pine64's IRC network diederik 5 1,186 11-13-2023, 07:36 PM
Last Post: ilebagels
  pine64 opensource dumbphone Phie 13 3,945 08-16-2023, 02:29 PM
Last Post: Phie
  Link USB power strips for a cluster? DevonBirch 4 3,458 08-10-2023, 09:11 PM
Last Post: halibutdreary
  Possible new Pine64 product - Pine Blue Ray DVD Linux tv box Omnios 5 1,542 07-24-2023, 03:21 PM
Last Post: Omnios
  My Pine64 Logo Re-Design & Thoughts About A New Logo me! 0 717 04-24-2023, 10:03 PM
Last Post: me!
