Screen Power Consumption Brightness=0 vs Turn off
Heya
I have a question regarding the power consumption of the screen on the Pinephone. I was under the impression that if the screen brightness is 0 that the power consumption of the display should be very low. But there seems to be a huge difference between turning the screen off and setting the brightness to 0. Could someone explain this to me? I understand that while the screen is on and the brightness is 0, we still are still drawing, but I don't expect that to cost 0.5w. I don't know much about display technologies and the hardware behind getting them running, but I would appreciate an explanation.
0.90w: xrandr --output DSI-1 --off (OR xset dpms force off OR xset dpms force standby OR however you want to turn of the screen Tongue )
1.44w: echo 0     > /sys/devices/platform/backlight/backlight/backlight/brightness
1.49w: echo 100 > /sys/devices/platform/backlight/backlight/backlight/brightness
1.51w: echo 200 > /sys/devices/platform/backlight/backlight/backlight/brightness
2.08w: echo 600 > /sys/devices/platform/backlight/backlight/backlight/brightness
Many thanks Big Grin
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 578 02-17-2024, 04:15 PM
Last Post: vortex
Tongue Screen ghosting and omitting rows of pixels... bedtime 0 401 12-28-2023, 01:26 PM
Last Post: bedtime
  Replacement screen disconnects after back frame is screwed on robthebold 4 1,430 10-12-2023, 01:03 PM
Last Post: robthebold
  Phone will not turn on (but sometimes will) insidetrip101 10 4,879 08-18-2023, 04:28 AM
Last Post: spha
  Pinephone - broken power button rorus 10 9,340 05-18-2023, 09:11 AM
Last Post: kbm
Thumbs Down Battery Issue or Power Management IC? bcoyle 2 1,556 03-20-2023, 12:54 AM
Last Post: bcoyle
  Screen dying already? marcih 153 147,412 02-23-2023, 04:14 AM
Last Post: Shatur
  Screen Replacement Instructions erikkugel 4 3,215 09-07-2022, 11:04 PM
Last Post: RTP
  Severe screen flicker + occasional ghosting | Pinephone Beta edition legowave440 5 3,714 07-25-2022, 07:35 AM
Last Post: bedtime
  Double Image on screen Arvis 2 1,787 07-03-2022, 06:27 AM
Last Post: Avisando
