Double Image on screen
My Pinephone with Convergence package arrived yesterday
I powered it on and the first couple of set up screens worked fine then the screen started flickering with a second fainter image appearing about 1cm above the main image on the screen. (eg the time is shown twice, with the fainter ghost image  above flickering up and down)
I managed to run the updates, and I charged the battery, and I have rebooted several times but it is still  the same
Has anyone met this problem or have any suggestions as to what is happening?
That is likely a defective screen, I would recommend you to open a ticket at support.pine64.org and to attach an picture of the issue there.
(06-29-2022, 03:11 PM)Arvis Wrote: My Pinephone with Convergence package arrived yesterday
the problem may be with the operating system that came pre-installed with your PinePhone. So I recommend that you flash the latest "Manjaro Plasma Mobile" image to your PinePhone to see if that fixes the problem.
The link to download the image: https://github.com/manjaro-pinephone/pla...2205290338
Tongue Screen ghosting and omitting rows of pixels... bedtime 0 270 12-28-2023, 01:26 PM
Last Post: bedtime
  Replacement screen disconnects after back frame is screwed on robthebold 4 1,123 10-12-2023, 01:03 PM
Last Post: robthebold
  Screen dying already? marcih 153 140,313 02-23-2023, 04:14 AM
Last Post: Shatur
  Screen Replacement Instructions erikkugel 4 2,960 09-07-2022, 11:04 PM
Last Post: RTP
  Severe screen flicker + occasional ghosting | Pinephone Beta edition legowave440 5 3,479 07-25-2022, 07:35 AM
Last Post: bedtime
  Screen has pixel-thin horizontal stripes that are black or get stuck in the past yasmi 5 3,866 03-08-2022, 12:25 PM
Last Post: jopple
  How hard to replace screen? Zebulon Walton 28 28,466 01-18-2022, 12:21 AM
Last Post: henrythemouse
  pinephone screen Uturn 2 2,183 01-14-2022, 01:15 AM
Last Post: Uturn
  Screen replacement Csanderson0313 4 3,112 01-10-2022, 09:26 PM
Last Post: Csanderson0313
  Top of screen and USB port malfunctioning Severinus 0 1,034 12-14-2021, 07:28 PM
Last Post: Severinus
