Severe screen flicker + occasional ghosting | Pinephone Beta edition
Hello all,
I wanted to reach out and see if there is a known solution to my issue.  I have the Pinephone Beta edition, purchased during the summer of 2020.  Since near the beginning, at random intervals, the screen would severely flicker whenever the backlight is >30% or so.  This happens at random intervals regardless of battery or charging status.  I have also noticed occasional ghosting on the display that persists after reboot.  I've reseated the display connector to no avail.
My distro is stock Postmarket, although I suspect this to be a hardware problem (perhaps with the display controller?)
Has anyone else experienced or resolved this issue?
I have seen screen flicker with Manjaro, openSUSE and SFOS.
I see it often, on both my original and the Pro, running all different OSs at different times. I've never been able to correlate it with screen brightness or phase of the moon or anything like that, it just happens, later it won't be happening.
***   Don't be a minion in the (i)droid army   ***
See here for some possible explanations. Unfortunately there seems to be no easy fix in sight.
Mind that one of the common causes for screen flickering is also if the phone wasn't shut down after the previous boot (e.g. it was forced off). The solution for that specific kind of flickering is to shut down the phone properly once (using the shutdown menu or using "poweroff") and then to boot it again.
Does the phone stop flickering when it's plugged in and charging?
Bug PinePhone modem keeps "disappearing" Kevin Kofler 21 23,958 09-11-2026, 09:18 AM
Last Post: idice
  Pinephone + Keyboard for sale, little use ruemoo 18 15,904 08-23-2026, 12:17 AM
Last Post: Nambo
  Pinephone - broken power button rorus 14 26,487 05-17-2026, 03:52 PM
Last Post: EuvzO8
  PinePhone 16 GB – Free to a Good Home Anna 2 2,654 01-20-2026, 01:43 PM
Last Post: Anna
Sad PinePhone USB-C port and audio jack failure Kevin Kofler 4 9,118 12-11-2025, 08:57 AM
Last Post: jakfish
  Recycling pinephone as home server mdk 6 4,707 12-01-2025, 02:57 AM
Last Post: mdk
  PinePhone, PinePhone Pro, Keyboard/Accessories for sale brb78 5 3,710 11-30-2025, 05:45 AM
  Modem Issues with the Pinephone Temmie19 5 7,272 07-02-2025, 12:50 PM
Question Third-party cheap touchscreen/LCD for the Pinephone - lost knowledge? mikeb 2 5,408 06-21-2025, 05:19 PM
Last Post: mikeb
  Screen dying already? marcih 156 310,421 06-12-2025, 06:18 AM
Last Post: mikeb
