Rooted Android LCD 64GB Image
I have tried downloading the 64GB Android with LCD image 3 times today. Each time it has failed right at the end. It will be at 648/648 MB and just sit at 0b/'s. Anyone else having trouble with this particular download?
Sent from my SM-G930V using Tapatalk
(06-13-2016, 04:40 PM)modsbyus Wrote: I have tried downloading the 64GB Android with LCD image 3 times today. Each time it has failed right at the end. It will be at 648/648 MB and just sit at 0b/'s. Anyone else having trouble with this particular download?
I know this is an old-ish thread but yes, I have the same issue.  I just got my play box and wanted to use the LCD (since I now have a way to actually mount it securely), and I was trying to download the 64gb rooted lcd version.  Same issues.  The chinese link also fails to even load.
I let it go for about 15 minutes and it did finally finish.  No idea what the issue is. It would be nice if there were more alternate links, or even torrents available.
Are there alternate download links available?  This project seems to be more and more of a lost cause every time I try to work on it.  I'm far from impressed with the play box.....
There should be enough torrent seeders with a full version. Failing that, have you tried using a download manager such as DownThemAll! ? If the download fails, it will pick up from where it last fell over, as opposed to having to redownload the entire package.
Getting the same issue.
My downloads don't finish. I can get the phoenix card image, but none of the android images that support LCD.
If I do wait long enough to get a .zip, it unpacks to .cpgz and is corrupt.
Any advice?
General Electric Services Director
https://twitter.com/predixavenger
http://Predix.io
  Pine A64 does only boot with Android 5.1 Dude 6 10,300 07-03-2022, 02:18 PM
Last Post: Dude
  Linux and Android unstable and stand still regularly AES 3 7,897 10-24-2016, 04:51 PM
Last Post: panoflex
  overlapping partitions issue with resize of 8GB image put on 16GB sd card dkryder 10 19,552 10-05-2016, 11:32 AM
Last Post: dkryder
  Rooted Android and LCD JoeHz 3 8,356 09-20-2016, 11:12 PM
Last Post: Ghost
  Just got my +2g up and going running Android Max_power 0 2,751 06-27-2016, 12:06 AM
Last Post: Max_power
  Android 64gig run smooth Ian_Hobson 8 17,840 06-09-2016, 08:38 PM
Last Post: Ian_Hobson
  MD5 (or SHA256) hashes for all image downloads? inactivist 1 4,617 04-25-2016, 12:39 AM
  Android and Linux BSP 1.2 Available for download ssvb 2 6,669 02-23-2016, 07:35 PM
Last Post: khgoh
