Pinephone - broken power button
So, I have been using my Pinephone, in a wallet case not designed for it, on a temporary basis. Was working well, but had to pop the Pinephone out of the case to press the power button.
Suddenly, a very soft "ping". The little dish-shaped aluminium plate came off the power button, revealing the two contacts (the inner copper dot and outer copper ring).
Power button still works if I short across the contacts with a conductive object.
Fixing the little aluminium plate back in place with a touch of cyanoacrylate glue did not restore the power button's function, had to remove it again.
Spoke to a friend we all call "MacGyver", he doesn't like even his chances of repairing a little momentary power button, says he's succeeded twice on about fifty devices attempted.
I need a replacement power button for the Pinephone. I've searched the datasheets and component list hoping for a component ID for the little momentary power button, but it only lists the larger modules.
Does anyone know what a suitable replacement button would be? Digikey component number or a link to eBay / Aliexpress would be most welcome!
(03-16-2021, 02:58 AM)rorus Wrote: ...
I guess what you need is 1 of these.
Sadly (but realistically - I realise P&P costs despite what fleabay would have me believe!) the P&P far outweighs the cost of the item though. If you are in the UK then there are some little bits I have been thinking of and could share the P&P?
Are we talking about this? https://pine64.com/product/pinephone-sid...46c16e2e66
No, this side flexband PCB does not include the small round bottons.
Thanks guys.
I'm in Australia, not the UK, but definitely interested if anyone has a source for a replacement!
(03-30-2021, 12:06 AM)rorus Wrote: Thanks guys.
The actual power and volume buttons are actually a part of the LCD screen. When you order a new screen, they send you a tiny decal with contacts on it to short the membranes on those tiny contacts when you depress the plastic outside part. $35USD
the part you are talking about is the "PINEPHONE SIDE KEYS FLEX PCB" and costs only 1 USD
I did not realize that was in the Pine Store (plus $15 shipping )
I ordered it (30/03) after reading the discussion, will let you guys know how the replacement goes when it arrives. Thanks everyone for your advice!
Were you able to replace this? Having a very similar issue with my power button
(04-05-2021, 04:21 PM)KNERD Wrote: The actual power and volume buttons are actually a part of the LCD screen.  When you order a new screen, they send you a tiny decal with contacts on it to short the membranes on those tiny contacts when you depress the plastic outside part.  $35USD
https://pine64.com/product/pinephone-sid...-flex-pcb/
  my pinephone melted norayr 6 915 04-04-2024, 07:22 PM
  Pinephone refusing to charge while suspended tiol 1 1,099 04-02-2024, 10:54 AM
Last Post: joH_N_Doe64
  various tricks to open the pinephone shengchieh 2 721 03-23-2024, 09:27 AM
Last Post: Ferriah
  pinephone can provide more than 500mA to a usb-c displayport device? unrznbl 2 357 03-21-2024, 08:52 AM
Last Post: unrznbl
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 566 02-17-2024, 04:15 PM
Last Post: vortex
  pinephone keyboard + dock question tuxcall 7 2,851 02-05-2024, 03:17 PM
Last Post: wigan
  Unsatisfactory GPS reception on PinePhone? LinAdmin2 53 56,047 12-17-2023, 11:42 AM
Last Post: robin.com.au
  PinePhone Pro not booting (Cap error!, pctl timeout) jealda 2 1,407 11-16-2023, 05:03 AM
Last Post: DrYak
  Pinephone frame damages Uturn 2 1,007 10-23-2023, 02:49 AM
Last Post: Uturn
  PinePhone Keyboard KJ6OHG 11 8,165 08-23-2023, 03:25 AM
Last Post: Kali
