Convergence dock not charging pinephone mobian
Anybody else experiencing this issue? Dock works fine for everything but it's draining my battery at a rate of about 2w. I though it might have been the usb port on my monitor i'm using it with, so I switched to a wall charger and when connected to the phone directly it charges, but as soon as I try to use it with the dock it's back to discharge mode. I'm running all the current updates on mobian at the moment.
We've got several threads on this issue. Mobian is missing patches that will permit it to charge above .5A, assuming that's the issue you are having. But it's basically unusable for anything but Ethernet w/ the screen off. There is a ticket / issue at Mobian on the matter but things haven't changed.
https://gitlab.com/mobian1/issues/-/issues/176
Maybe you can also let them know your experiences so that they know that several people would like to see these patches.
Hey,
don't know if you knew, but there's a new kernel image available which should fix most of the PD issues.
So to say the anx7688 driver finally got the latest updates... and arrived in Mobian.
Just try:
sudo apt-get install linux-image-5.11-sunxi64
Let the setup finish and reboot.
uname -a
Linux mobian 5.11-sunxi64 #1 SMP PREEMPT Wed Feb 24 23:40:32 UTC 2021 aarch64 GNU/Linux
See this as well:
https://repo.mobian-project.org/pool/mai...x-sunxi64/
It's so nice to see Big Grin
Hopefully this may fix your issues as well!!!
Cheers,
scholbert
I updated to 5.11 but still see power issues with my usb hub and computer. A charging wall wart works at 1.5A though.
(03-01-2021, 04:23 PM)scholbert Wrote: Hey,
Just try:
uname -a
See this as well:
Cheers,
scholbert
Thanks for the heads-up. Didn't seem to change anything here though with a few of the power supplies I've tested w/ the Convergence dock.
Yeah, thanks!
...though i seemed a little bit too optmistic.
My Apple HDMI multi adaptor still charging at 0.5A only...
Regards,
scholbert
It does report PD 2. I can't recall if it did previously. It may just need to have the current limit changed.
I do recall that Manjaro Phosh had all of this taken care of when I tested it.
The backlight does appear to flicker slightly with this kernel during discharge (while plugged in). You may need to adjust the brightness to 50%-70%  to see it.
(02-28-2021, 11:07 AM)tecnocris Wrote: Anybody else experiencing this issue? Dock works fine for everything but it's draining my battery at a rate of about 2w. I though it might have been the usb port on my monitor i'm using it with, so I switched to a wall charger and when connected to the phone directly it charges, but as soon as I try to use it with the dock it's back to discharge mode. I'm running all the current updates on mobian at the moment.
Its also because the usbc connectors contact surface is 1/16" to short.
The current operating system on your phone probably has some of the effects on the dock.
Using recent Mobian images, I have seen the charge limited to 0.5 amp on some occasions,
but at other times it says 2.0 amp...
.... this happens sometimes since our OSes are still relatively immature.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
  Case for Pinephone totilele 13 7,545 04-11-2024, 11:48 AM
Last Post: gramonyl
  keyboard case charging but not typing new2pinephone 18 5,961 02-19-2024, 07:30 AM
Last Post: theResonant
  PinePhone Dock with laptop? Mikey1977Y2J 2 667 12-12-2023, 05:43 PM
Last Post: Mikey1977Y2J
  Update the PinePhone keyboard driver to support missing characters? Peter Gamma 8 8,266 10-22-2023, 08:43 PM
Last Post: Peter Gamma
  key repeat with pinephone keyboard rotwang 0 468 10-22-2023, 03:39 PM
Last Post: rotwang
  Pinephone with mini keyboard, trackpad and large power bank? Peter Gamma 0 538 10-21-2023, 07:50 AM
  Use the Linux Console with the PinePhone Keyboard mburns 2 1,053 10-20-2023, 04:11 PM
Last Post: mburns
  Convergence package USB-C Docking Bar for Wired Ethernet (part II) Peter Gamma 4 1,000 10-08-2023, 11:49 PM
Last Post: zetabeta
  Mouse for the PinePhone? Peter Gamma 21 15,594 10-04-2023, 10:24 AM
  PinePhone Wallet Case Shane 5 5,094 09-17-2023, 12:52 PM
Last Post: J T
