Use Pinebook (not pro) image for pineTAB?
I believe I read on the pine64 block or wiki that a pineobok distro 'should' or 'might' work on a pineTAB, possibly with some minor adjustments?
I know that is pretty vague .... sorry.  :-)
I was looking to try a Manjaro-ARM distro, and the TAB flavors lag the *book and *Pro devs by quite a bit.
Thanks,
Dennis
Dennis Hoshield
PBPro/ANSI/Manjaro
I'm curious about the same thing, the PineTab is similar to the PineBook so my intuition says that it should work, but I'm not so sure
In theory it should work, I would suggest to give it a go. Some hardware may not work correctly, but you should be able to get close.
  PineTab 2 login screen rotation fix chzbacon 11 4,142 03-17-2024, 04:53 PM
Last Post: mtomaschett
  NixOS on PineTab 2 asonix 3 2,105 02-24-2024, 12:29 PM
Last Post: Evergreen
  Working OS on pinetab RISC-V? user641 3 821 12-13-2023, 08:11 AM
  Pinetab 2 as Pinebook Pro replacement Corkonian 4 2,272 08-15-2023, 11:22 AM
Last Post: CadenAnderson
  Software for PineTab-V msm 12 4,668 08-05-2023, 05:08 PM
Last Post: bingch
  Arch Linux ARM on PineTab 1 Danct12 25 29,836 06-10-2023, 05:33 PM
Last Post: fxc
  PineTab 2 Login Failure cptijerina 0 701 06-07-2023, 07:16 PM
Last Post: cptijerina
  PineTab Mobian bcnaz 150 147,368 04-26-2022, 11:58 AM
Last Post: thomzane
  Xmonad on PineTab Telefza 0 1,825 06-24-2021, 04:04 AM
Last Post: Telefza
  PineTab Mobian Upgrade issue - Pin no longer works thomzane 3 4,135 04-30-2021, 06:52 AM
Last Post: thomzane
