Pinetab 2 as Pinebook Pro replacement
I am a huge supporter of SBC and low-power computing and I've been using a *lot* of Pine64 systems over the years. I used to run A64, original 14" and 12" PineBooks and the 14" PineBook Pro.
I have retired everything but the PineBook Pro, as memory and CPU no longer live up to modern standards.
The original Pinebook Pro is showing its age, too and I blindly ordered a PineTab 2 to replace the PineBook Pro. More RAM always helps.
I do not intend to run the PineTab 2 as a tablet, screen real estate is too small, but I will keep the keyboard always attached, so no special tablet features are needed.
Given the architectural similarities between PineBook Pro and PineTab 2, will the PineBook Pro Manjaro run on the PineTab 2/??
Unless something has changed, it seems that Danknix Arch is the only thing that runs on it so far.
I wish I had time and money to try getting NetBSD working on it.
:wq
[ SRA accepts you ]
(06-05-2023, 06:32 AM)Corkonian Wrote: Given the architectural similarities between PineBook Pro and PineTab 2, will the PineBook Pro Manjaro run on the PineTab 2/??
No, they are very different devices.
Do keep in mind that the PineTab2's CPU is a little weaker than the Pinebook Pro's. The PineTab2 is a replacement for the PineTab1, not the PbP.
I suspect we'll see a true PbP successor once RK3588 mainline support is in better shape.
Occasional Linux Kernel Contributor, Avid Wiki Updater, Ask Me About Quartz64
Open Hardware Quartz64 Model A TOSLink Adapter
Pi-bus GPIO Extender For ROCKPro64 And Quartz64 Model A
Plebian GNU/Linux
thanks
  PineTab 2 login screen rotation fix chzbacon 11 4,152 03-17-2024, 04:53 PM
Last Post: mtomaschett
  NixOS on PineTab 2 asonix 3 2,113 02-24-2024, 12:29 PM
Last Post: Evergreen
  Working OS on pinetab RISC-V? user641 3 829 12-13-2023, 08:11 AM
  Software for PineTab-V msm 12 4,692 08-05-2023, 05:08 PM
Last Post: bingch
  Arch Linux ARM on PineTab 1 Danct12 25 29,842 06-10-2023, 05:33 PM
Last Post: fxc
  PineTab 2 Login Failure cptijerina 0 702 06-07-2023, 07:16 PM
Last Post: cptijerina
  PineTab Mobian bcnaz 150 147,394 04-26-2022, 11:58 AM
Last Post: thomzane
  Xmonad on PineTab Telefza 0 1,826 06-24-2021, 04:04 AM
Last Post: Telefza
  PineTab Mobian Upgrade issue - Pin no longer works thomzane 3 4,139 04-30-2021, 06:52 AM
Last Post: thomzane
  Video Tutorial: SDR/GQRX- Listening In To Voice On Pinetab (Internal SDR) RTP 1 2,496 03-08-2021, 09:33 AM
Last Post: barray
