01-30-2021, 09:13 PM
The statusbar and titlebars of King's Cross are taking up a lot of real estate. I would say this is true of a lot of these gnome apps. Is there a way to force full screen?
Make King's Cross (and apps in general) fullscreen
01-31-2021, 02:29 AM
yes, I use it daily !
with dconf editor assign a value, "<Alt>f" for instance, to org.gnome.wm.keybindings.toggle-fullscreen you can then use it using the terminal layout of squeekboard
01-31-2021, 03:34 AM
and to get more space, I set the scale to 1.5 in /usr/share/phosh/phoc.ini
you can change that at runtime with wlr-randr
02-03-2021, 03:37 PM
(01-31-2021, 02:29 AM)fdlamotte Wrote: yes, I use it daily ! OK so I can set <Alt>f to toggle fullscreen. But for the life of me I cannot get <Alt>m (or anything) to minimise the current window. Or do we have a <Super> key in squeakboard to use the default <Super>h? I really like the Telegram option to start minimised - it is out of sight until it has something to look at. However after opening it the first time it would be nice to get rid of it/minimise it again.
02-04-2021, 04:21 AM
@dukla2000 if you look at phoc sourcecode there is nothing to take care of the minimize keybinding
https://salsa.debian.org/agx/phoc/-/blob...bindings.c so unfortunatelay there seems to be no way of minimizing a window ...
02-04-2021, 04:37 AM
(02-04-2021, 04:21 AM)fdlamotte Wrote: @dukla2000 if you look at phoc sourcecode there is nothing to take care of the minimize keybinding thanks
Keyboard not popping up on QT apps | 3x5co | 1 | 252 |
02-08-2024, 11:45 PM Last Post: Kevin Kofler |
Giving certain audio apps priority on the lock screen and pulldown | 3x5co | 0 | 863 |
07-17-2022, 10:34 AM Last Post: 3x5co |
Using lat/lon in GPS/GNSS apps and Messaging | biketool | 6 | 3,188 |
05-04-2022, 11:45 AM Last Post: wibble |
Apps and SD Card | biketool | 2 | 1,905 |
03-06-2022, 09:47 AM Last Post: biketool |
Cross compilation for Mobian | nicolapcweek94 | 3 | 2,783 |
02-21-2022, 02:42 AM Last Post: nicolapcweek94 |
Reskinning Apps for Mobile | biketool | 6 | 3,442 |
12-05-2021, 02:30 PM Last Post: biketool |
no access to webdav files (for some apps) | jsch | 0 | 1,257 |
11-13-2021, 09:46 AM Last Post: jsch |
How to Make Mobian Boot to Command Line | Ubermunchen | 4 | 3,507 |
11-02-2021, 08:34 AM Last Post: ryo |
Make scale setting persistent | 3x5co | 2 | 2,182 |
10-26-2021, 05:57 PM Last Post: 3x5co |
Sizing apps to fit to screen | county93 | 4 | 3,390 |
10-23-2021, 11:36 PM Last Post: bcnaz |
