Wifi very slow on PBP Manjaro?
My pbp  is 1 month old running default Manjaro it came with.
I am able to connect to wifi but I am only gettting 0.33, and up to 1,5 Mbits/s. On the same connection my phone get 12+ Mbits/s.
What are some tips for me to debug this? I'm not even sure how to do the proper updates.
So far I've done all the updates in the software center, in whatever the UI system is on Manjaro (separate question: what is the UI/GUI called on Manjaro), and ran pamac update && paman upgrade and this did some stuff.
KDE Plasma is the Desktop Environment.
As for the speed, all I can say is I find that it's slow, too. But I haven't measured it.
The more I use Manjaro the less I like it, so I can't comment too much on how to use it. FWIW I haven't really compared WiFi speeds on the PBP without Manjaro. When I run Debian I never give it any thought, and when I run NetBSD, I expect it to be slower because I'm using a slow USB WiFi adaptor, not the internal one.
What I can say is that the inbuilt WiFi adaptor and antenna seem to be lacking. I get terrible connectivity with it, and that may be the reason why it's slow.
Here in Debian Sid (unstable) I get ~110Mbps downstream and ~125Mbps upstream with built-in Wi-Fi on a D-Link DIR-890L access point with 1Gbps symmetric link to the world. I get two-three times higher speeds on other laptops, and almost full gigabit on wired machines, so the Wi-Fi card in PBP is definitely the weak link.
This message was created with 100% recycled electrons
  Manjaro versions bad and good gilwood 0 249 02-12-2024, 05:03 PM
Last Post: gilwood
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,224 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 694 12-13-2023, 08:17 PM
Last Post: trillobite
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 802 07-13-2023, 01:50 PM
Last Post: PaulQ
  Games compilation howto on the Pinebook-pro (Manjaro Linux and Debian native) astr0baby 201 318,937 05-12-2023, 06:09 AM
Last Post: korreckj328
  Manjaro Plasma blinking cursor jcun4128 4 1,473 05-08-2023, 11:17 AM
  PBP blank screen after updating Manjaro Franko 6 2,020 04-01-2023, 07:55 AM
Last Post: hacknix
  Manjaro - which libdrm? hacknix 0 571 04-01-2023, 03:21 AM
Last Post: hacknix
  wifi missing some networks filip 0 582 03-11-2023, 03:21 PM
Last Post: filip
Sad Very slow download speeds? intervalz 8 6,972 02-09-2023, 11:51 PM
Last Post: gulshan212
