speaker replace and no screen
Hi eveyone!
I recently replace my loudspeaker for my pinephone postmarketos.
I use the Nokia N91.
https://wiki.pine64.org/wiki/PinePhone#S...ne64_store
When i start the phone, i see the green light showing up (12 secondes) and the screen doesn't display.
If i press the power button the black of the screen come more "light" and i press again to get it back to "dark" black.
No *tic* from the hardware when it boot. (like when starting the camera apps)
I can hold the power button to shutdown..
Can someone have any idea what i can do next?
Thank!
Use the serial terminal via the headphone jack to see what's actually happening during boot. Details are in the wiki
(01-19-2021, 08:03 AM)wibble Wrote: Use the serial terminal via the headphone jack to see what's actually happening during boot. Details are in the wiki
Thank wibble!
via the socat command i was able to see the boot process.
There is the "error" message i found..
[    7.075354] sun4i-drm display-engine: [drm] Cannot find any crtc or sizes
[    6.945232] panel-sitronix-st7703 1ca0000.dsi.0: [drm:st7703_probe] *ERROR* mipi_dsi_attach failed (-517). Is host ready?
[    8.140653] Goodix-TS 1-005d: Direct firmware load for goodix_917S_cfg.bin failed with error -2
dmesg | grep -i goodix
[    8.156955] Goodix-TS 1-005d: ID 917S, version: 0200
[    8.162282] Goodix-TS 1-005d: Direct firmware load for goodix_917S_cfg.bin failed with error -2
[    8.185374] input: Goodix Capacitive TouchScreen as /devices/platform/soc/1c2ac00.i2c/i2c-1/1-005d/input/input2
dmesg | grep -i panel-sitronix
[    6.949232] panel-sitronix-st7703 1ca0000.dsi.0: [drm:st7703_probe] *ERROR* mipi_dsi_attach failed (-517).
Is host ready?
[    7.462466] panel-sitronix-st7703 1ca0000.dsi.0: [drm:st7703_probe] 720x1440@60 24bpp dsi 4dl - ready
dmesg | grep -i sun4i-drm
[    6.992743] sun4i-drm display-engine: bound 1100000.mixer (ops sun8i_mixer_ops)
[    7.004567] sun4i-drm display-engine: bound 1200000.mixer (ops sun8i_mixer_ops)
[    7.012509] sun4i-drm display-engine: No panel or bridge found... RGB output disabled
[    7.020361] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops sun4i_tcon_ops)
[    7.028684] sun4i-drm display-engine: bound 1c0d000.lcd-controller (ops sun4i_tcon_ops)
[    7.036724] sun4i-drm display-engine: bound 1ca0000.dsi (ops sun6i_dsi_ops)
[    7.063300] sun4i-drm display-engine: bound 1ee0000.hdmi (ops sun8i_dw_hdmi_ops)
[    7.071537] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 1
[    7.079359] sun4i-drm display-engine: [drm] Cannot find any crtc or sizes
[    7.106776] sun4i-drm display-engine: [drm] Cannot find any crtc or sizes
[    7.448143] sun4i-drm display-engine: [drm] fb0: sun4i-drmdrmfb frame buffer device
Is it a problem whit the connector and the screen?
Thank!
Tongue Screen ghosting and omitting rows of pixels... bedtime 0 388 12-28-2023, 01:26 PM
Last Post: bedtime
  Replacement screen disconnects after back frame is screwed on robthebold 4 1,360 10-12-2023, 01:03 PM
Last Post: robthebold
  Screen dying already? marcih 153 146,061 02-23-2023, 04:14 AM
Last Post: Shatur
Bug DESIGN ISSUE? Speaker + vibration motor broke for the 2nd time e1337 11 4,392 01-26-2023, 10:11 PM
Last Post: AnAbolitionist
  Screen Replacement Instructions erikkugel 4 3,163 09-07-2022, 11:04 PM
Last Post: RTP
  Severe screen flicker + occasional ghosting | Pinephone Beta edition legowave440 5 3,654 07-25-2022, 07:35 AM
Last Post: bedtime
  Double Image on screen Arvis 2 1,742 07-03-2022, 06:27 AM
Last Post: Avisando
  Screen has pixel-thin horizontal stripes that are black or get stuck in the past yasmi 5 4,027 03-08-2022, 12:25 PM
Last Post: jopple
  How hard to replace screen? Zebulon Walton 28 29,229 01-18-2022, 12:21 AM
Last Post: henrythemouse
  pinephone screen Uturn 2 2,290 01-14-2022, 01:15 AM
Last Post: Uturn
