PinePhone postmarketOS edition does not boot up properly anymore, black screen loops
So I've had my postmarketOS device for several months now.
About two days ago, after I shut it down, it loops to a black screen after I enter my password and the postmarketOS image appears and the kernel info shows. All that is visible is the terminal cursor blinking at the top left corner. It loops until I hard reset or runs out of battery power.
I've tried attached a microSD card to the phone per other people's advice before booting but that does not address the problem.
I don't have any images to demonstrate but I would appreciate any advice to further diagnosing the issue. It will take some time and resources, however, to obtain another Linux device that could connect to the board. Perhaps the flash memory is full?
Would it be recommended to trigger the Reset button on the back?
Did you put an OS on the SD?
(01-11-2021, 11:59 PM)Veraendert Wrote: Did you put an OS on the SD?
I am having this problem too.
I have not installed the OS to the SD card.
After boot I get the Mobian splash screen and then nothing.
Any ideas?
I've read something about Mobian and a difficult update that may result in a black screen. I'll look it up. Meanwhile, you can still boot an OS from SD card.
Should be this problem: https://forum.pine64.org/showthread.php?tid=13275
  PinePhone - boot from microSD laserpyramid 7 630 04-25-2024, 05:56 AM
Last Post: aular
  pinephone virtual keyboard aular 4 367 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 246 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 109,645 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,856 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 625 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,411 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 511 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,737 12-22-2023, 03:44 PM
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 7,005 12-04-2023, 02:14 AM
Last Post: Peter Gamma
