Flash non-bootable eMMC?
Hi everyone, I've managed to come up with a non-bootable eMMC after attempting to install Gentoo.
I can boot from SD if I turn the eMMC switch to off, but can't boot from SD with with the eMMC switch on. Obviously, in this scenario with the eMMC off, I can't flash a new OS to the eMMC.
What's the proper method to getting a functional OS back on the eMMC? Or more preferably, boot from SD with the eMMC switch on so I can continue to tinker with the Gentoo install that's on there? Thanks!
turn off emmc, boot from sd, turn on emmc, rebind emmc in terminal, wipe/write. the commands to bind the emmc can be found on the primary pbp wiki page.
Thanks, @tophneal, that did the trick! I didn't realize the emmc could reinitialize while the system was running.
Sad What to can't boot from TF card, EMMC system broken - any advice?do guys? qingss0 1 1,265 12-18-2025, 01:05 AM
Last Post: qingss0
  swap eMMC advice jceaser 2 1,609 10-23-2025, 09:59 PM
  Need new eMMC Karsten1 2 3,693 10-23-2025, 09:38 AM
Last Post: jceaser
  Happy eMMC and SDcard OS usage for Pinebook Pro Newbies... Paulie420 42 99,249 11-20-2023, 06:22 PM
  Selling my Pinebook Pro with a bootable NVMe WD SSD drive pinemouth 0 2,469 09-27-2023, 08:53 PM
Last Post: pinemouth
  I'm booting from NVME but I want to switch back to eMMC acruhl 4 5,837 04-23-2023, 06:58 AM
Last Post: acruhl
  Doesn’t power on after flashing emmc badguru 3 4,823 02-25-2023, 09:00 PM
Last Post: badguru
  eMMC problem with Tow-Boot/u-boot on SPI repa 3 5,064 02-21-2023, 01:49 AM
Last Post: repa
  Partial boot after installing Manjaro on emmc regivanx 11 10,920 02-06-2023, 09:11 AM
  Unable to Boot anything (emmc or SDcard) line72 5 6,421 01-17-2023, 12:07 PM
Last Post: nfms
