Keyboard touchpad
I received my PineTab yesterday and preformed the initial setup and installed the updates without the keyboard attached. After the updates completed, I shutdown the tablet and restarted with the keyboard connected.
I encountered the touchpad invisible box bounding problem as described elsewhere in the forum. I engaged the system settings rotation lock button which did not correct the problem, so I returned it to the default off position. I did not see an option to manually select landscape mode anywhere in the system settings to see if the tablet was stuck in portrait mode.
Is there a fix for this problem that I may have missed in the forum?
  Keyboard issue mshelby 2 3,038 11-22-2023, 09:14 AM
Last Post: mshelby
Exclamation Pinetab2 Keyboard Issues lockedpotato 0 2,139 10-14-2023, 05:48 PM
Last Post: lockedpotato
  Offer: PineTab with keyboard firefox-58 3 7,606 09-27-2021, 12:36 PM
Last Post: stmguard
  (I managed to...) Botched keyboard/trackpad firmware zivben 7 15,773 11-22-2020, 03:29 PM
Last Post: gnuoob
  Pinetab attachable keyboard fritz 7 15,255 11-02-2020, 09:29 AM
Last Post: fritz
  Keyboard Layout guenther 2 6,475 06-10-2020, 08:00 AM
Last Post: guenther
