Buying used vs next pre-order of Manjaro Convergence?
Hello, pardon if this is the wrong place to post this. I see Manjaro KDE Pinephone is what is now offered in the store for pre-order. If a buyer specifically wanted the Manjaro Convergence package, is finding one on the used market pretty much the only option right now? Any projections on the next pre-order availability of Manjaro Convergence Pinephone?
thank you
Seems like that's going to be the case, yes.
But I don't really think you should worry too much about it, the only differences are the OS they're running on and the back cover, both of which can be user replaced.
Apart from that, the next phone isn't a Manjaro KDE edition, it's just KDE edition.
If still unsatisfied, you might find a used phone online, I've seen many people who bought one being disappointed and sold it after very slight usage.
母語は日本語ですが、英語も喋れます(ry
(12-06-2020, 05:25 PM)ryo Wrote: Seems like that's going to be the case, yes.
OK, thanks! yeah, showing my noob-ness being concerned about what's installed Smile  I found a Manjaro convergence package used and made the purchase, looking forward to checking it out. thanks for the quick reply.
  Manjaro: Settings doesnt open nbh 0 598 09-24-2023, 05:25 PM
Last Post: nbh
  Can't get ring on Manjaro Pine Phone thorensjubilee 12 3,525 06-09-2023, 04:40 AM
Last Post: thorensjubilee
  Is Manjaro ARM a Rolling Release? jojuma 4 1,608 05-10-2023, 09:27 PM
  Where Does Manjaro Phosh Store Its Custom Keystrokes? jakfish 0 816 04-25-2023, 09:49 AM
Last Post: jakfish
Exclamation My short experience with Manjaro Plasma Mobile anonymous 10 4,813 03-02-2023, 07:25 PM
  Can't install Manjaro thorensjubilee 1 1,038 02-09-2023, 08:17 AM
  Manjaro plasma-mobile Beta 13 Uturn 13 4,927 01-25-2023, 04:15 PM
  Manjaro Plasma busted Chief 2 1,590 11-22-2022, 05:00 PM
Last Post: Chief
  MMS workaround for users with separate APN (works atleast on Manjaro Phosh) alaraajavamma 0 1,079 10-10-2022, 12:53 PM
Last Post: alaraajavamma
Question Running AnBox on Manjaro ARM w/ Phosh? danimations 2 2,511 09-05-2022, 03:42 PM
Last Post: nroth
