How to boot from SD card on pinebook pro
Hello.
Recently, i've tried to install manjaro XFCE on to my pinebook pro.
I burned the image to an SD card, and inserted it into my pinebook pro.
When I boot, I get the orange power light, followed by the green, but no video output.
This is really stumping me.
What type of SD are you using? I could be one that doesn't play well with booting on the PBP. Do you have any USB thumbdrives laying around? If Manjaro came installed on your emmc, you can boot from that, too. Or you cn also try booting this installer image https://osdn.net/projects/manjaro-arm/st....04.img.xz (it's older, but updateable. for some reason there are reports of issues booting the newer SD-to-emmc installers.)
Thanks for the help.
I'm using a SanDisk 32GB microSD, and I do have an 8GB USB drive.
I will try burning that image you mentioned, and I will give you updates.
Much appreciated
Update:
I burned 20.04 to my card.
It boots regularly, but horribly slow.
No difference.
Thanks anyway though
  Running Linux on Pinebook Pro with External Monitor Twers1962 2 816 03-25-2025, 11:10 PM
Last Post: Dendrocalamus64
  Pinebook Pro vs Pinetab2 Lotech 5 2,121 12-10-2024, 09:10 PM
  Maximum size of boot MicroSD for RockPro64 and Pinebook Pro commiecam 3 2,893 12-10-2024, 07:23 PM
  [Star64] Help needed in understanding Yocto and U-boot build process InterestedinFOSS 0 1,162 04-23-2024, 10:58 AM
Last Post: InterestedinFOSS
  Boot Ox64 after SPI Flash IC replacement kotnitro 1 2,247 05-26-2023, 02:19 AM
Last Post: kotnitro
  Star64 first boot (and success) bortzmeyer 1 2,922 05-24-2023, 02:45 AM
Last Post: draintroup
Exclamation Quartz64 model a wont boot AndyNZAUS 0 2,240 09-13-2022, 06:35 AM
Last Post: AndyNZAUS
  Please Help: Bricked Pinebook Pro with Keyboard Update dumbguywhobrokehiscomputer 3 5,712 07-14-2021, 02:49 PM
  Java on Manjaro ARM Pinebook Pro gulagpyromaniac 3 5,337 05-25-2021, 11:05 AM
  Setup My Pinebook 64 and Lost Password jersdayoff 5 9,255 05-01-2021, 10:29 PM
