Quartz64 model a wont boot
Exclamation
Hey all
I'm new to the pine world, have used other sbc's multiple times. I've got the quartz64 model A, installed a 32Gb emmc module and using a power adaptor from the pine store (https://pine64.com/product/12v-5a-us-power-supply/). When I plug in the power supply I get the green DC light, I've followed the instructions from this link: https://wiki.pine64.org/wiki/Installing_...e_Quartz64
I have a 16Gb SD card in my laptop, run this command (SD card is mounted as sda):
sudo -i; xzcat images/rk3566-quartz64-a.dtb.img.xz > /dev/sda
Terminal then shows "[root@fedora ~]#"
I enter "sudo sync"
I get no errors but also get no output just goes to the next line showing "[root@fedora ~]#"
Am I suppose to get some output? When I go into the device in file explorer it shows as empty, In terminal after the sync command if I run LS I see anaconda.cfg, eclipse, eclipse-workplace, rpmbuild, snap and another directory named with Asian characters
I've put this SD card into the pine, plugged in the power and no output on the screen, I pressed and also tried holding down the power button, still no output, tried the same with the reset button and still nothing. I've tried removing the emmc module and retried the buttons and removing repluging in the power, still nothing. and also with the SD card unplugged too, still nothing on screen
What else can I try? or have I missed something?
I've tried searching online but unable to find further resources
  Hello All! New user - 2 basic Quartz64 questions oldschool 2 882 12-14-2023, 12:06 AM
Last Post: oldschool
  linux-headers and quartz64-post-install package conflicts Berzerkleyfan 2 642 12-01-2023, 05:17 AM
Last Post: Berzerkleyfan
  Boot Ox64 after SPI Flash IC replacement kotnitro 1 1,135 05-26-2023, 02:19 AM
Last Post: kotnitro
  Star64 first boot (and success) bortzmeyer 1 1,572 05-24-2023, 02:45 AM
Last Post: draintroup
  Soquartz - what image for Model A baseboard? kbanfield 0 1,450 10-14-2022, 10:38 AM
Last Post: kbanfield
  Maximum size of boot MicroSD for RockPro64 and Pinebook Pro commiecam 0 1,690 08-07-2022, 10:47 AM
Last Post: commiecam
  Wi-Fi/Bluetooth for PINE64, Model: Sopine A64 lamson 0 1,742 08-24-2021, 08:17 AM
Last Post: lamson
  How to boot from SD card on pinebook pro linux123 3 6,048 12-02-2020, 10:29 AM
Last Post: linux123
Lightbulb Live boot with persistence? r00tn3rd 1 3,222 10-23-2020, 01:30 AM
Last Post: HotChocolate
  Occasional boot toiny 0 2,142 10-18-2020, 01:41 PM
Last Post: toiny
