Manjaro system update failed, bricked PinePhone
I received my PinePhone today with manjaro preinstalled.
I wanted to update the os, the system update was stuck for ~1hour in searching update.
So i opened the terminal and run
sudo pacman -Syuu
The update got stuck at an error about perl and default local. I couldn't do nothing, the phone did not respond so after 1 hour I removed the battery.
Now, when I start it the red led lights is showing up, but on the screen... nothing.
I bought an SDXC ScanDisk extreme 64GB, put ubuntu touch on it..and nothing. No red led light, nothing on screen.
I used the Pine64 installer to create the bootable SD card.
The image I downloaded from here: https://ci.ubports.com/job/rootfs/job/rootfs-pinephone/ .
What should I try to make it work?
Thank you.
(11-26-2020, 06:32 AM)jalanga Wrote: Hi,
sudo pacman -Syuu
Thank you.
You can't brick the PinePhone. Fully charge the phone and just use the instructions from the Wiki to write to SD: https://wiki.pine64.org/wiki/PinePhone_I...structions using the current Ubports repo over at https://ci.ubports.com/job/rootfs/job/ro...stemimage/ as the repo you have been using is outdated (it says so at the top of the page).
  PinePhone Game Thread PixelPaintbrush 31 80,032 06-11-2026, 02:50 PM
Last Post: elinkser
  How can I record video on a Pinephone? kk22 23 22,183 03-25-2026, 12:55 PM
Last Post: baptx
  Pinephone visibly losing power while plugged in Hiraghm 8 6,914 03-09-2026, 07:51 PM
Last Post: Tia Vaughan
  pinephone-support package not upgradable on Mobian fhireman 5 7,111 02-28-2026, 05:49 PM
Last Post: baptx
Exclamation No wIfI after Mobian update crakabeats 5 7,100 02-28-2026, 04:18 PM
Last Post: baptx
  beep - playing PCM samples on PinePhone? WhiteHexagon 0 956 12-04-2025, 08:07 AM
Last Post: WhiteHexagon
Star Selling my Pinephone Pro Explorer Edition zheyon 2 4,191 12-01-2025, 10:25 AM
  PinePhone sensors - Gyroscope power WhiteHexagon 3 1,741 11-30-2025, 08:07 AM
  Light Sensor / Proximity Sensor on PinePhone? WhiteHexagon 1 1,344 11-18-2025, 03:07 PM
  Pinephone boot. Richy_T 8 6,765 10-21-2025, 12:12 PM
Last Post: Richy_T
