New OS for RockPro64 is here, TwisterOS Armbian
#91
For anyone on a Mac of Win machine, having trouble with the instruction to edit armbianEnv.txt:
1. Windows and Mac cant out of the box mount the eMMC (and SD I suppose), so you can't edit /boot/armbianEnv.txt
2. If you don't have a linux box at hand, you can use VirtualBox with USB passthrough, following this tutorial:
 https://www.linuxbabe.com/virtualbox/acc...x-guest-os
After configuring the attaching the USB device with your virtual system you will be able to mount the partition and edit the file.
https://github.com/dibrz/ARMBand easily maintain an ARM64 media server
I am having issues using Twister on a Pinebook pro.  This is probably a noob question.  The instructions say after flashing the twister image to edit the /boot/armbianEnv.txt file.  But this file is read only - (I assume because the partition is mounted).  And I haven't been able to figure out a workaround.   Can anyone explain the process of editing this file?
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 1 516 03-25-2024, 12:12 PM
  yocto for RockPro64 Fide 1 735 01-16-2024, 10:01 AM
Last Post: Fide
  Installing Ubuntu Server on RockPro64 deutschlmao 2 2,656 10-29-2023, 04:43 PM
Last Post: brotherj4mes
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 17,534 08-16-2023, 01:34 AM
Last Post: varac
  slarm64 (unofficial slackware) ROCKPro64 RK3399 (aarch64) mara 54 83,692 08-11-2023, 11:13 AM
  How to enable CoreSight ETM trace on RockPro64 shpark 0 601 05-21-2023, 11:34 PM
Last Post: shpark
  Rockpro64 Dead on arrival? quixoticgeek 1 970 03-12-2023, 06:55 PM
Last Post: quixoticgeek
  RockPro64 boot questions misterc 3 1,606 01-13-2023, 06:21 PM
Last Post: misterc
  A fix for Bluetooth audio stuttering on the RockPro64 raph 2 1,683 01-03-2023, 06:53 PM
Last Post: raph
  hello i want to drive an edp screen with my rockpro64 hannescam 0 769 10-20-2022, 01:22 PM
Last Post: hannescam
