Have you opened your pinetab and did the screen crack when snapping back together?
Yes, screen's fine
80.00%
4
Yes, screen's fine, also have screen protector
0%
0
Yes, screen cracked Sad
0%
0
Yes, screen cracked, also have screen protector Sad
20.00%
1
No. Never going to open it up
0%
0
5 vote(s)
Opening the back and screen cracks
Hi all,
I've joined the ranks of those with a cracked digitizer/screen from opening and closing the back panel. This was after I installed a tempered glass screen protector, so I wonder if that's maybe part of the cause (possibly not letting the screen flex ever so slightly when snapping the back on?). With my first pinetab I opened and closed the back 4+ times for testing cables and such (bad touchscreen) with zero issues. With this one, I opened it only once to swap in a higher capacity eMMC, when snapping it back together it didn't feel like there was any extra tension/stress but it wound up with a corner crack. Easy enough to move the tray to the other side so losing touch there isn't a big deal, still going to be one of the first in line to buy a replacement screen if/when they're available.
So I pose a question/poll. Just wondering how many have popped it open and reassembled without issue or have had a screen crack. Furthermore, if the screen cracked was there a screen protector involved? Wondering if this might be a common mode of failure or not.
  Pinetab2 screen removal Corconegre 5 1,351 01-10-2024, 08:08 AM
Last Post: stozi
  ?brighter screen replacement for pinetab (>1600 nits) dynobang 0 542 09-28-2023, 01:06 PM
Last Post: dynobang
  PineTab2 screen won't turn back on until reboot KelsonV 3 1,056 08-23-2023, 09:08 AM
Last Post: diederik
  Pinetab 2 screen no longer coming on Fibonacci 9 2,996 06-30-2023, 08:26 AM
Last Post: Purple_Illusion
Big Grin Howto: Pinetab Screen Replacements (+ Pictures) RTP 5 6,433 02-10-2022, 08:31 PM
Last Post: barray
  Possible screen resolution upgrade in the next batch? marcinus 2 3,659 07-19-2021, 09:14 AM
Last Post: swiley
  Moving lines on screen SpoofyKid 5 6,326 05-01-2021, 09:52 PM
Last Post: SpoofyKid
  Howto Video: Opening Pinetab RTP 0 2,449 02-14-2021, 10:25 PM
Last Post: RTP
  video of opening up pinetab? hanscees 0 2,638 11-09-2020, 12:47 PM
Last Post: hanscees
  Replacement Screen Options NerdyOwl 0 2,238 10-18-2020, 10:53 PM
Last Post: NerdyOwl
