How get gcc for new PineTab?
I just got my new PineTab.
I'd like to get gcc running from the shell.
pacman does not seem to be available.
any hints appreciated on how to more ahead.
Which OS are you running? Pacman will only be on Arch and derivatives. Mobian uses apt and postmarketOS uses apk. UBPorts is a bit different, and probably not what you want if you're trying to run gcc from shell.
https://wiki.pine64.org/index.php?title=PineTab
  PineTab 2 login screen rotation fix chzbacon 11 4,121 03-17-2024, 04:53 PM
Last Post: mtomaschett
  NixOS on PineTab 2 asonix 3 2,103 02-24-2024, 12:29 PM
Last Post: Evergreen
  Working OS on pinetab RISC-V? user641 3 820 12-13-2023, 08:11 AM
  Pinetab 2 as Pinebook Pro replacement Corkonian 4 2,266 08-15-2023, 11:22 AM
Last Post: CadenAnderson
  Software for PineTab-V msm 12 4,665 08-05-2023, 05:08 PM
Last Post: bingch
  Arch Linux ARM on PineTab 1 Danct12 25 29,824 06-10-2023, 05:33 PM
Last Post: fxc
  PineTab 2 Login Failure cptijerina 0 697 06-07-2023, 07:16 PM
Last Post: cptijerina
  PineTab Mobian bcnaz 150 147,314 04-26-2022, 11:58 AM
Last Post: thomzane
  Xmonad on PineTab Telefza 0 1,824 06-24-2021, 04:04 AM
Last Post: Telefza
  PineTab Mobian Upgrade issue - Pin no longer works thomzane 3 4,133 04-30-2021, 06:52 AM
Last Post: thomzane
