Battery Weight/Removing back cover frequently
What is the battery Weight? Can you buy spare back covers as they're not designed to be frequently used, and how many will you need. Do you still sell spare parts only for repairs including the batteries. I'd like to be able to remove the battery if I intend to use the thing in bed and was wondering how much lighter it would get.
(09-24-2020, 05:01 AM)janat08 Wrote: What is the battery Weight? Can you buy spare back covers as they're not designed to be frequently used, and how many will you need. Do you still sell spare parts only for repairs including the batteries. I'd like to be able to remove the battery if I intend to use the thing in bed and was wondering how much lighter it would get.
Naked battery not allow for international shipping and Pine Store no intent to sell the PineTab battery.
  Battery discharges completely while the Tab2 is powered off between less than 24hs nonic 3 639 12-07-2023, 10:35 AM
Last Post: dachalife
  PineTab2 screen won't turn back on until reboot KelsonV 3 1,037 08-23-2023, 09:08 AM
Last Post: diederik
  Battery mshelby 2 924 08-22-2023, 08:22 AM
Last Post: alpopa
  Can the PineTab work without the battery? Luattoli 3 5,163 12-06-2020, 09:37 PM
  Opening the back and screen cracks quipacorn 0 2,208 10-12-2020, 01:01 PM
Last Post: quipacorn
  Removing Back to PineTab publiclewdness 5 8,851 09-19-2020, 02:45 PM
