==> ERROR: visual-studio-code-bin is not available for the 'aarch64' architecture.
I'm trying to install vscode. Google and vscode official site directs me here https://aur.archlinux.org/packages/visua...o-code-bin
I run makepkg -si and I get the above error once I've downloaded the repo and switched to the folder with bin. How can I install vscode? I have the default manjaro.
Looks like a problem with the package: https://forum.manjaro.org/t/vscodium-wor...gain/13978
Edit: my mistake, you were talking about the official vscode which does not have an aarch64 (ARM) package. The Pinebooks have ARM processors and cannot use x86 packages. Try the vscodium package instead.
(09-22-2020, 07:57 PM)motezart Wrote: I'm trying to install vscode. Google and vscode official site directs me here https://aur.archlinux.org/packages/visua...o-code-bin
I'm no expert on make but if you change architecture (arch=) in an Arch aur pkgbuild to include aarch64 it can build to work on arm, I did it with timeshift in Manjaro's aur and it built and works.
Unfortunately that's a binary package. So it's a no go
Have you come across this? https://github.com/futurejones/code-oss-aarch64
I have not tried with pbp, but I did managed to build vscode in PINE A64 with dietpi os and it is working fine
Sent from my HTC U11 using Tapatalk
(10-01-2020, 07:10 PM)Darren Wrote: Have you come across this? https://github.com/futurejones/code-oss-aarch64
So how can I do this since it's for Ubuntu using apt and I have Manjaro? These are all rookie questions but this is my first time using anything outside a major OS or linux flavour.
I'm getting fed up with it cuz my pbp is just a brick so far using it.
I tried to use vscodium https://github.com/VSCodium/vscodium which I then go to https://aur.archlinux.org/packages/vscodium-bin/. But there are no instructions on how to run this. What do I do?
I've also tried installing snap and following this https://snapcraft.io/install/code/manjaro#install but I get `GLIBC_2.28' not found when I even try to just run snap command, so nothing related specifically to vscode. Any further advice? I haven't been able to debug this issue yet via googling.
(10-09-2020, 03:00 PM)motezart Wrote: I tried to use vscodium https://github.com/VSCodium/vscodium which I then go to https://aur.archlinux.org/packages/vscodium-bin/. But there are no instructions on how to run this. What do I do?
Just how you tried to do it before?
https://wiki.manjaro.org/index.php/Arch_...UR_by_hand
$ git clone https://aur.archlinux.org/vscodium-bin.git
$ cd vscodium-bin
$ makepkg -si
(I did makepkg -s and then installed it,
$ sudo pacman -U vscodium-bin-1.50.0-1-aarch64.pkg.tar.xz)
Then VSCodium shows up under Xfce's application menu in the Development section and seems to run. Or invoke as vscodium from the command line.
How do I tell what GIU I have? Mine looks different than Xcfe.
For some reason makepkg -s  or -si returned command not found. I somehow got plain makepkg to work. I then has able to click on vscodium-bin.desktop and get the editor to run. Hopefully it will works as expected now!
I have noticed today, that there are official ARM64 releases of vscode now: https://code.visualstudio.com/#alt-downloads Wink
I have tried the .tar.gz version on Manjaro and seems to work well.
(10-12-2020, 09:59 AM)501idni Wrote: I have noticed today, that there are official ARM64 releases of vscode now: https://code.visualstudio.com/#alt-downloads Wink
This really a great news, we can see that arm64 getting more and more support
  Various freezes during boot & while running several Linux distros - hardware error? donuts 1 3,640 11-22-2023, 11:47 AM
Last Post: fxc
  U-Boot, video console, and visual artifacts dsimic 21 37,916 03-16-2023, 07:30 AM
Last Post: Tazdevl
  Pass code lock on pinephone Notatechie 0 2,383 01-13-2023, 10:53 PM
Last Post: Notatechie
Photo pamac error "could not find database" Paulperry3 0 2,636 07-15-2021, 08:55 PM
Last Post: Paulperry3
  OBS Studio or alternative on Pinebook Pro? charlespine 4 10,948 09-26-2020, 07:59 AM
Last Post: khan
Lightbulb (Manjaro) Manipulate AUR PKGBUILD so that it builds on aarch64 Opvolger 0 4,249 06-06-2020, 10:10 AM
Last Post: Opvolger
  Possible bug? Preloaded OS compiled for aarch64 but dpkg set to armhf tequilasunrise 7 12,065 01-19-2020, 07:23 PM
Last Post: xmixahlx
  Expired coupon code :-( frank-zappa 3 10,529 08-26-2019, 02:23 PM
Last Post: frank-zappa
  Please help me with order Pinebook Pro - I got an expired code from pine64 Wawe 11 24,857 08-26-2019, 12:46 PM
Last Post: c6Q$!
  Requesting PBP coupon code lgrajn 5 14,814 08-25-2019, 06:58 PM
Last Post: Eggmonkey
