(Manjaro) Manipulate AUR PKGBUILD so that it builds on aarch64
Lightbulb
Manjaro is completely new to me (not linux). My desktop runs with linux (dual boot) and I have been able to play with Rpi 1,2,3 over the years. But now an aarch64 pinebook pro laptop!
Spent the past 3 days to see what is possible on this laptop. Quite a lot, just miss DRM (netflix, prime, disney +).
I also notice that many community packages (AUR) do not work for aarch64 (only i686 and x86_64). So I immediately started to make them myself:
- https://aur.archlinux.org/packages/openarena-git/
- https://aur.archlinux.org/packages/libxmp-aarch64-git/
But found out today that you can still edit the PKGBUILD files for the build. So you can easily add aarch64 to the list of architectures and a lot will work already.
Here with screenshots ...
Click on "edit build files" and add aarch64 click on "Save" and you're done!
[Image: click_on_edit_build_files.png]
[Image: edit_PKGBUILD.png]
I notice that not all "versions" work. You really notice that aarch64 is newer in the world. For example, nblood didn't work but nblood-git did (newer code I think) eduke32 worked, but ran into a few problems, now building eduke32-git
if a build succeeds and works, I immediately ask in the comment if they want to add aarch64.
The future is here! ARM laptops!
  Manjaro versions bad and good gilwood 0 242 02-12-2024, 05:03 PM
Last Post: gilwood
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,195 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 674 12-13-2023, 08:17 PM
Last Post: trillobite
  Games compilation howto on the Pinebook-pro (Manjaro Linux and Debian native) astr0baby 201 318,156 05-12-2023, 06:09 AM
Last Post: korreckj328
  Manjaro Plasma blinking cursor jcun4128 4 1,459 05-08-2023, 11:17 AM
  PBP blank screen after updating Manjaro Franko 6 2,004 04-01-2023, 07:55 AM
Last Post: hacknix
  Manjaro - which libdrm? hacknix 0 566 04-01-2023, 03:21 AM
Last Post: hacknix
  Partial boot after installing Manjaro on emmc regivanx 11 3,161 02-06-2023, 09:11 AM
  Manjaro pinebookpro images with kernel 5.7.19 rfm83 11 4,755 01-22-2023, 10:05 PM
Last Post: rfm83
  No boot after Manjaro flash PBcurry 14 5,454 10-03-2022, 08:33 PM
