PinePhone CAD Models for Design Improvements
Does anyone have a link to the PinePhone CAD models? I might have a design improvement or two that I would like to implement using CAD and either make a custom part or contribute them directly to the Pine64 PinePhone project. If someone would care to share them I would appreciate it, thank you.
There are CAD files on the wiki, have you checked those, yet?
I was only able to find the back cover CAD file (bottom link in the section): https://wiki.pine64.org/PinePhone#Datash...eripherals
I found the exploded view here: http://files.pine64.org/doc/datasheet/pi...%201.0.pdf
I'd especially be interested in a CAD file for component #9, the "Bottom-case". This would make designing attachable peripherals for the pogo pins much easier!
The part and respective CAD file that I need is labeled "Bottom-case" in the PinePhone diagram which is the actual frame of the phone itself. I'd like to implement a design improvement in the frame to vastly increase it's durability.
I was hoping one of the developers such as Luke would share the CAD file with me either in this thread or privately so I don't have to order the part from China? It would save me time drawing it in FreeCAD, I won't have to wait 2-4 weeks for it to arrive, and I would only have to make modifications and testing.
(08-06-2020, 10:26 AM)jamie22 Wrote:
(08-05-2020, 10:24 AM)bridadan Wrote: I was only able to find the back cover CAD file (bottom link in the section): https://wiki.pine64.org/PinePhone#Datash...eripherals
I found the exploded view do my assignment australia here: http://files.pine64.org/doc/datasheet/pi...%201.0.pdf
I will check out these files now. Thanks for the links.
What is this URL that appeared in the quote? I can't find it in the original post, so weird
.png   Annotation 2020-09-08 114455.png (Size: 93 KB / Downloads: 422)
  Case for Pinephone totilele 13 7,222 04-11-2024, 11:48 AM
Last Post: gramonyl
  PinePhone Dock with laptop? Mikey1977Y2J 2 635 12-12-2023, 05:43 PM
Last Post: Mikey1977Y2J
  Update the PinePhone keyboard driver to support missing characters? Peter Gamma 8 8,165 10-22-2023, 08:43 PM
Last Post: Peter Gamma
  key repeat with pinephone keyboard rotwang 0 449 10-22-2023, 03:39 PM
Last Post: rotwang
  Pinephone with mini keyboard, trackpad and large power bank? Peter Gamma 0 514 10-21-2023, 07:50 AM
  Use the Linux Console with the PinePhone Keyboard mburns 2 1,021 10-20-2023, 04:11 PM
Last Post: mburns
  Mouse for the PinePhone? Peter Gamma 21 15,297 10-04-2023, 10:24 AM
  PinePhone Wallet Case Shane 5 5,026 09-17-2023, 12:52 PM
Last Post: J T
  KB: Using bus powered USB peripherals with the pinephone keyboard mounted docsunset 9 37,382 08-07-2023, 06:12 AM
Last Post: mikeb
  PinePhone flex breakout board with Grove female header jnpine 0 634 08-04-2023, 10:47 PM
Last Post: jnpine
