Upgrade problem
(07-28-2020, 01:59 PM)jed Wrote: Clever. Well done Smile
Thanks  Smile
Well, I "unsolved" this issue. It turned out that the modified lists are getting overwritten with the same content after an update again. So I had to chattr +i the files. I don't think that this very dirty workaround is a good one, although at least for now updates/installations are working good...
Issue seems to be solved now finally after I learnt of somebody else with the same issue, that it is finally solved.
  Mobian boot failed with zstd message after upgrade. Mahgue 0 643 09-01-2023, 11:29 AM
Last Post: Mahgue
  Problem with updates: Repository 'Debian bookworm' changed its 'non-free component' Anna 7 2,473 08-31-2023, 12:38 PM
Last Post: vusra
  MODEM - Usb problem & couldn't query SIM slots: QMI protocol freelectro 5 2,857 06-06-2023, 06:36 AM
Last Post: freelectro
Wink Pinephone lost graphic during mobian system upgrade cmpin 4 2,214 03-01-2023, 04:45 PM
Last Post: anonymous
  No boot after upgrade: vibration, red LED, then 2 vibrations and yellow LED 3x5co 1 1,003 01-04-2023, 06:46 PM
Last Post: 3x5co
  Battery problem with a Pinephone keyboard and Mobian elode 2 2,215 12-22-2022, 07:10 PM
Last Post: acid andy
  Receive MMS fails after Nov 27 upgrade treebeard 17 6,016 12-12-2022, 05:09 AM
  Dist-upgrade and Chatty vs Gnome-Contacts biketool 9 4,087 09-30-2022, 08:53 PM
Last Post: treebeard
  Modem Firmware Upgrade - Modem Busy - USB Issues biketool 10 4,837 09-23-2022, 05:15 AM
  New Tow-boot release, how to upgrade? user641 3 1,904 08-23-2022, 08:45 AM
Last Post: user641
