New Tow-boot release, how to upgrade?
There's a new version of tow-boot, upgrading is just repeating the first install? Flash to sd and run it in the phone?
(08-22-2022, 10:32 AM)user641 Wrote: There's a new version of tow-boot, upgrading is just repeating the first install? Flash to sd and run it in the phone?
Exactly that, super easy!
Any new features or bug fixes pertaining to the Pinephone? The description for the release says "If you're not booting your operating system via UEFI, there is no need to upgrade."
(08-23-2022, 07:18 AM)Zebulon Walton Wrote: Any new features or bug fixes pertaining to the Pinephone? The description for the release says "If you're not booting your operating system via UEFI, there is no need to upgrade."
Indeed I saw that too, maybe it's just a good practice to keep it updated. If there's a new patch, could we just upgrade to the latest version or must upgrade each one at a time?
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,022 11-22-2023, 11:46 AM
Last Post: aLoop100o
  How to check if tow-boot is installed? jojuma 3 957 09-29-2023, 11:29 PM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 643 09-01-2023, 11:29 AM
Last Post: Mahgue
  4G data on default startup / boot dcinoz 1 846 04-29-2023, 11:24 PM
Last Post: dcinoz
  PinePhone won't boot after software update jb2000 2 1,347 03-17-2023, 07:26 AM
  Boot log analyses -> GPU no regulator (mali) found freelectro 0 973 03-06-2023, 12:06 PM
Last Post: freelectro
Wink Pinephone lost graphic during mobian system upgrade cmpin 4 2,211 03-01-2023, 04:45 PM
Last Post: anonymous
  boot gets stuck shortly after disk decryption vortex 8 4,039 02-13-2023, 02:11 AM
Last Post: sharase
  [solved] Black screen at boot time mdk 0 1,018 01-13-2023, 03:33 AM
Last Post: mdk
  No boot after upgrade: vibration, red LED, then 2 vibrations and yellow LED 3x5co 1 1,001 01-04-2023, 06:46 PM
Last Post: 3x5co
