Screen Brightness Question
I hate to ask this, but in Mobian, how does one make the screen brighter? I cannot seem to find anything setting for that function.
Well...this one I figured out on my own. It was in the power section in settings. I will tell you, I purchased the UBPorts version of this phone. The Mobian install works 10,000 times better than the UBPorts software that came preinstalled. I am running it off the card. Trying to see if there is any reason I would want to keep a piece of software on this phone that does not work. Namely the entire install.
(07-11-2020, 09:21 PM)LinuxBrave Wrote: Well...this one I figured out on my own. It was in the power section in settings. I will tell you, I purchased the UBPorts version of this phone. The Mobian install works 10,000 times better than the UBPorts software that came preinstalled. I am running it off the card. Trying to see if there is any reason I would want to keep a piece of software on this phone that does not work. Namely the entire install.
I replaced the Ubuntu Touch OS with Mobian on the eMMc and I have no regrets. I just tried Ubuntu Touch on an SD card and it's still as buggy as the day I first tried it.
How will I know the phone is done being flashed? How long does it take?
I used the 'status=progress' flag for the dd command, which gives you a progress bar as the image is being flashed. The PinePhone's LED blinks red while the image is being written. Mobian took ~10 minutes. There's a stickied thread on the forum for flashing to eMMc as well.
sudo dd if=mobianImage.img of=/dev/sdX status=progress
I appreciate the info. I went ahead and flashed my Pinephone to Mobian last night. Mobian works WAY better than UBPorts. I think after one is able to figure out the thing with MMS, they would be very close to having a fully functional install for phones that will take the build. If our phones had double the ram and double the processor, with additional built in storage, these phones would be more mainstream.
  OpenTTD game - Error: no usable screen resolutions found. eugenr 3 6,020 06-23-2026, 01:12 AM
Last Post: Mary_Davis
  Trixie - bring up the On Screen Keyboard manually. grump_fiddle_reinstall 0 1,017 12-23-2025, 04:34 AM
  On-Screen Keyboard Arrow Keys biketool 11 10,360 12-23-2025, 04:25 AM
  How to add an homemade app to the main screen? JChdeL 3 1,906 11-04-2025, 04:13 AM
Last Post: JChdeL
  New Install, apps start but don't show up on screen?! RT3 2 3,145 07-18-2025, 07:56 PM
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 4,190 01-15-2025, 08:08 PM
  Proximity sensor is oversensitive (was "Screen blanks when making call") treebeard 6 9,952 08-05-2024, 06:12 AM
Last Post: baptx
  Quick question abtut sources.list jojuma 1 2,704 06-17-2024, 04:46 AM
Last Post: zetabeta
  Screen auto-rotation sensitivity mdk 0 2,312 12-26-2023, 06:08 AM
Last Post: mdk
  Screen stay black unless power key pressed short freelectro 0 2,446 06-24-2023, 01:55 PM
Last Post: freelectro
