WIFi hotspot
I am not sure when this stated working.
I checked yesterday and the menu entry was enabled, so I gave it a try.
It worked flawlessly. I connected three debian devices and did apt-get upgrades. Not once the connection was dropped and speed was around 1Mb/s. With my previous android based phone this was a nightmare: connections were dropped randomly, download speed was sluggish.
Again thank you for making this real.
For me the gotcha was having to disable bluetooth to get the menu entry working. It's a bit confusing because there's no warning or indicator to tell you this is the case, but once I figured that out it has been working perfectly for the last week or so.
(07-08-2020, 07:02 AM)Djhg2000 Wrote: For me the gotcha was having to disable bluetooth to get the menu entry working. It's a bit confusing because there's no warning or indicator to tell you this is the case, but once I figured that out it has been working perfectly for the last week or so.
Ok, thanks. It could be. I think bluetooth was disabled on my PP to save battery time, but I didn't bother to check, if it was really so, or only a UI toggle button with no function at all.
  reset wifi hardware/driver when it dies through console on pp? tuxcall 5 5,795 03-10-2026, 04:43 PM
Last Post: baptx
  Pinephone seems tobe using 4G data instead of Wifi data grump_fiddle_reinstall 7 6,491 02-20-2025, 02:47 PM
Last Post: puffchumpy
  How to enable ipv6 for hotspot robgadget 1 2,694 04-28-2023, 06:59 AM
Last Post: wibble
  Wifi doesn't work after update nickolas 2 4,087 04-14-2023, 10:07 AM
Last Post: nickolas
  Recent install, no wifi user641 3 4,308 01-12-2023, 03:06 PM
Last Post: user641
  Wifi issue since last update and held back updates goku499 11 13,916 09-21-2022, 02:39 PM
Last Post: Katsujinken
  Hotspot and IPv6 gosh000 1 2,588 06-08-2022, 02:12 AM
Last Post: wibble
  Problem with wifi kubussz 0 1,875 04-02-2022, 12:57 PM
Last Post: kubussz
  Scripting Bluetooth Hotspot for Mobian biketool 1 3,314 03-20-2022, 03:03 PM
  wifi adapter not found.. why? b7l3wui26r 3 4,504 11-29-2021, 10:28 AM
Last Post: beta-user
