Ir codes for Android 9
Is there any way to get IR codes on Android images.
Any drivers, tools ... etc presents there?
Grep shows something related irc and lirc:
./proc/kallsyms:0000000000000000 t nf_conntrack_irc_fini ./proc/kallsyms:0000000000000000 R __ksymtab_nf_nat_irc_hook ./proc/kallsyms:0000000000000000 r __kcrctab_nf_nat_irc_hook ./proc/kallsyms:0000000000000000 r __kstrtab_nf_nat_irc_hook ./proc/kallsyms:0000000000000000 t init_rc_map_lirc ./proc/kallsyms:0000000000000000 t nf_conntrack_irc_init ./proc/kallsyms:0000000000000000 t nf_nat_irc_init ./proc/kallsyms:0000000000000000 t exit_rc_map_lirc ./proc/kallsyms:0000000000000000 t nf_nat_irc_fini ./proc/kallsyms:0000000000000000 t __initcall_init_rc_map_lirc6 ./proc/kallsyms:0000000000000000 t __initcall_nf_conntrack_irc_init6 ./proc/kallsyms:0000000000000000 t __initcall_nf_nat_irc_init6 ./proc/kallsyms:0000000000000000 D nf_nat_irc_hook ./proc/kallsyms:0000000000000000 d irc ./proc/kallsyms:0000000000000000 d lirc_map ./proc/kallsyms:0000000000000000 b lirc ./proc/kallsyms:0000000000000000 b irc_buffer_lock ./proc/kallsyms:0000000000000000 b irc_buffer ./proc/kallsyms:0000000000000000 b irc_exp_policy
A little bit more info about device:
getevent -lp /dev/input/event0 add device 1: /dev/input/event0   name:    "ff1b0030.pwm"   events:     KEY (0001): KEY_1                KEY_2                KEY_3                KEY_4                                KEY_5                KEY_6                KEY_7                KEY_8                                KEY_9                KEY_0                KEY_BACKSPACE        KEY_HOME                            KEY_UP                KEY_LEFT              KEY_RIGHT            KEY_DOWN                            KEY_DELETE            KEY_MUTE              KEY_VOLUMEDOWN        KEY_VOLUMEUP                        KEY_POWER            KEY_MENU              KEY_SETUP            KEY_WAKEUP                          KEY_BACK              KEY_PLAYPAUSE        KEY_F13              KEY_F14                              KEY_F15              KEY_F16              KEY_SEARCH            KEY_REPLY                            KEY_TEXT              KEY_BLUE              KEY_CHANNELUP          input props:     <none>
+ this:
rk3328_box:/ # getevent -i /dev/input/event0        add device 1: /dev/input/event0   bus:      0019   vendor    0001   product   0001   version   0100   name:     "ff1b0030.pwm"   location: "gpio-keys/remotectl"   id:       ""   version:  1.0.1   events:     KEY (0001): 0002  0003  0004  0005  0006  0007  0008  0009                 000a  000b  000e  0066  0067  0069  006a  006c                 006f  0071  0072  0073  0074  008b  008d  008f                 009e  00a4  00b7  00b8  00b9  00ba  00d9  00e8                 0184  0191  0192   input props:     <none>
Somehow this codes should be mapped to this remote?
http://files.pine64.org/doc/Pine%20A64%2...t-logo.jpg
Found more info.
About ir driver: http://wiki.t-firefly.com/en/AIO-3399C/driver_ir.html
Source code of that driver:
https://gitlab.com/TeeFirefly/px3se-buil...emotectl.c
https://github.com/ayufan-rock64/android...emotectl.c
Tool to get key info:
https://source.android.com/devices/input/getevent
Chinese document regarding ir on rockchip:
https://translate.google.com/translate?h...2F89457743
I do have a device that could send any ir codes.
Doing a brute force right now.
Found that key codes:
0x404000FF or 0xFF -> KEY_0
0x404010EF -> KEY_8
Finally found this ir codes:
0x18E7; //KEY_VOLUMEUP
0xE817; //KEY_VOLUMEDOWN
0x58A7; //KEY_HOME
0xA25D; //KEY_BACK
0x08F7; //KEY_LEFT
0x8877; //KEY_RIGHT
0xFB04F; //KEY_REPLY <- not working
0xF807; //KEY_SEARCH
0x50AF; //KEY_MUTE
0xE21D; //KEY_TEXT
0xB24D; //KEY_POWER
0xD02F; //KEY_UP
0x708F; //KEY_DOWN
0x50AF; //KEY_MUTE
0x30CF; //KEY_DELETE
0xE00FF; //KEY_0
0x807F; //KEY_1
0x40BF; //KEY_2
0xE20DF; //KEY_4
0xA05F; //KEY_5
0x609F; //KEY_6
0x10EF; //KEY_8
0xE906F; //KEY_9
I've used this tool to find IR codes:
https://github.com/mdhiggins/ESP8266-HTTP-IR-Blaster
All codes in NEC 32 length format.
So sample curl to execute:
curl -X GET http://{your_device_ip}/msg?code=FF:NEC:32&simple=1
Unfortunately KEY_POWER ir code is unable to wake up device from power off state.
I've looked for home automation, so this is a kind of useless for me Sad
  Android Images (ROCK64) pineadmin 77 245,828 11-18-2024, 08:21 AM
Last Post: reukiodo
Wink Android ( Stock or TV version ) rooted image please !!! AngelfromSpain 5 13,406 05-13-2024, 12:32 PM
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 13,691 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 11,857 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 8,855 06-27-2021, 02:38 PM
Last Post: clach04
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 7,560 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 6,731 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 11,384 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 5,663 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 9,023 09-18-2020, 07:58 PM
Last Post: BowerR64
