Computer doesn't see PinePhone running UT when plugged into computer
I am trying to put some music/podcasts on my PinePhone running Ubuntu Touch and noticed that when I plug my PinePhone into my laptop using the cord sent with the phone, the phone starts charging but I can't see the phone in the file manager and running "fdisk -l" I also don't see the phone. Anyone else having a similar issue or know a workaround? I am running Linux Mint on my computer for what it's worth.
(06-29-2020, 09:44 AM)ragreenburg Wrote: I am trying to put some music/podcasts on my PinePhone running Ubuntu Touch and noticed that when I plug my PinePhone into my laptop using the cord sent with the phone, the phone starts charging but I can't see the phone in the file manager and running "fdisk -l" I also don't see the phone. Anyone else having a similar issue or know a workaround? I am running Linux Mint on my computer for what it's worth.
What works, what doesn't?
And yes, the Pinephone is maybe not your daily driver yet. See the list to get an idea where we are!
[/url]Working
  • Actors: Manual brightness
  • Actors: Notification LED
  • Actors: Vibration
  • Cellular: Carrier info, signal strength
  • Cellular: Data connection
  • Cellular: Incoming, outgoing calls
  • Cellular: PIN unlock
  • Cellular: SMS in, out
  • Cellular: Voice in calls
  • GPU: Boot into UI
  • Misc: Battery percentage
  • Misc: Charging
  • Misc: Shutdown / Reboot
  • Network:Flight mode
  • Sensors: Automatic brightness
  • Sensors: Proximity
  • Sensors: Rotation
  • Sensors: Touchscreen
  • Sound: Loudspeaker
  • Sound: Volume control
[url=#working-but-unstablebuggy]
Working but unstable/buggy
  • Network: Bluetooth (only works after cold boot)
  • Network: WiFi (only works well after warm reboot)
  • Network: Hotspot
[url=#not-working][/url]Not working
  • Actors: Torchlight
  • Camera: Flashlight
  • Camera: Photo
  • Camera: Video
  • Cellular: Change audio routings
  • Cellular: MMS in, out
  • GPU: Video acceleration
  • Misc: Reset to factory defaults
  • Sensors: GPS
  • Sound: Earphones
  • Sound: Microphone
  • USB: MTP access
  • USB: RNDIS access
So they know it dosen't work, I hope they will fix this cause I got the same problem
[/url]Working
  • Actors: Vibration
  • GPU: Boot into UI
  • Misc: Charging
  • Sensors: Rotation
  • Network: Hotspot
  • Camera: Photo
  • Camera: Video
  • Sensors: GPS
  • Sound: Earphones
  • Sound: Microphone
  • USB: MTP access
  • USB: RNDIS access
Thank you for that list! The reason I was wanting to plug it in and transfer the music/podcasts was because the wifi can be so buggy, as noted. Though luckily I've been having some good luck with it today so I've been able to get some podcasts for my commute. I am super excited for the next couple months as this phone hopefully develops into a daily driver. Do you happen to notice any other way to get music on the phone other than external transfer?
  PinePhone - boot from microSD laserpyramid 7 581 Yesterday, 05:56 AM
Last Post: aular
  pinephone virtual keyboard aular 4 353 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 236 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 109,126 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,800 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 611 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,372 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 499 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,699 12-22-2023, 03:44 PM
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 6,965 12-04-2023, 02:14 AM
Last Post: Peter Gamma
