PineTab Mobian
#91
Hi folks!
Geary and lollypop ask for the password of keyring at first startup after a reboot, because keyring is locked. Password of keyring is the same as the user (mobian) but different to the default "1234". Any ideas?
(10-20-2020, 09:21 AM)firefox-58 Wrote: Yepp, so the build is quite useless ATM
And has been sitting in this broken state for many days now.  Ugh, Mobian for Pinetab was looking great!
Fixed in the latest phosh version, today.
Hi, folks.
I have two problems concerning mobian on pinetab.
1) apt repository problem?
When I try
sudo apy update
then
Hit:1 ....
Hit:2 ...
Error time out
Reading package list ... done
Because I use Japanese language mode, maybe the messages above are not completely same as those of English.
I have tried several times but always failed. It seems partially updated. partially failed to update.
2) Bluetooth doesn't work at all.
Pinetab says it can't find bluetooth. To use bluetooth, please insert dungle.
Hello everyone,
As we're preparing a major transition to 5.9 kernel (and a couple other things under the hood), some packages incompatible with the current 5.8 kernel will be uploaded in the coming days.
It is recommended that you don't update your system for a few days and backup your personal data. You might even have to reflash a new image if the upgrade goes wrong (which is quite likely to happen).
Please note a u-boot upgrade will be part of the transition and will require manual action to install the new bootloader (see wiki).
Thanks for your understanding, hopefully this will be our last breaking change.
@a-wai  Thank you for the info. If I get it right, we should wait till the 5.9 kernel is in the update list?! Is there a "sudo u-boot-install-pinetab" command or just use "sudo u-boot-install-pinephone" for the u-boot upgrade?
Yes, there's a `u-boot-install-pinetab` script for the pinetab.
Regarding the upgrade, 5.9 is already in, but I have yet to find a way to automate various things required for it to boot properly due to heavy changes wrt the boot process. If you're impatient you can flash today's nightly, but I'm not yet sure I won't break more stuff in the coming days Wink
Perfect, Thank You! I will be patient and wait. The PineTab with Mobian works, at least for my needs, as a daily driver nearly perfect. Thank You for your work!
(11-04-2020, 08:55 AM)guenther Wrote: Perfect, Thank You! I will be patient and wait. The PineTab with Mobian works, at least for my needs, as a daily driver nearly perfect. Thank You for your work!
Does anybody know the last stable nightly build for the Pinetab?  I'd like to drop back to something I can use on the tablet until A-Wai catches up with all his rework.
Thanks!
Thanks!
You might want to give Arch Linux ARM a try. I like Mobian also, but Arch Linux ARM has things working that still had issues in Mobian. My biggest issue with Arch was the onscreen keyboard size, but that has been fixed. BT and sound work too.
  PineTab 2 login screen rotation fix chzbacon 11 4,121 03-17-2024, 04:53 PM
Last Post: mtomaschett
  NixOS on PineTab 2 asonix 3 2,103 02-24-2024, 12:29 PM
Last Post: Evergreen
  [PineTab2] Issues with Mobian Networking Cornelia Xaos 7 2,667 12-30-2023, 10:02 PM
Last Post: Cornelia Xaos
  Mobian Boot Problem rogerwegmann 14 3,839 12-13-2023, 11:04 AM
Last Post: diederik
  Working OS on pinetab RISC-V? user641 3 820 12-13-2023, 08:11 AM
  Mobian won't boot after ton of updates bartgrefte 11 4,795 12-10-2023, 02:47 AM
Last Post: bartgrefte
  Pinetab 2 as Pinebook Pro replacement Corkonian 4 2,266 08-15-2023, 11:22 AM
Last Post: CadenAnderson
  Software for PineTab-V msm 12 4,665 08-05-2023, 05:08 PM
Last Post: bingch
  Mobian - Phosh frtodd 1 1,239 06-18-2023, 04:51 AM
Last Post: GloriousCoffee
  Arch Linux ARM on PineTab 1 Danct12 25 29,823 06-10-2023, 05:33 PM
Last Post: fxc
