Sometimes screen turns on, sometimes not
Got in my Pinebook Pro a week ago and have been using it here and there.  I like it, but there's a problem.  Sometimes when I turn it on, so does the screen, but more often, the screen doesn't turn.  The light is orange for a few seconds then green, but no video output.  Anyone have insight on this one or do I have a faulty unit?  It's only warranted for 30 days so if there's a problem I'd like to get on it quickly.  If it's something I can handle by opening it up and doing something inside, I'm very comfortable with that sort of thing.
Assuming your pinebook pro came with Manjaro pre-installed it sounds like you are facing the u-boot related issues described in those threads: https://forum.pine64.org/showthread.php?tid=9981https://forum.pine64.org/showthread.php?tid=10031
(06-06-2020, 01:49 AM)khanku Wrote: Assuming your pinebook pro came with Manjaro pre-installed it sounds like you are facing the u-boot related issues described in those threads: https://forum.pine64.org/showthread.php?tid=9981https://forum.pine64.org/showthread.php?tid=10031
I think that did the trick, I'll give it a day or two of use to confirm and mark it resolved.
Forgot to come back and mark this as resolved, but it's resolved. Huzzah!
  Another one boots to black screen Sb2024 7 7,257 11-06-2024, 11:27 PM
Last Post: Sb2024
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 2,346 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Black screen by start up bluedemon382 10 11,343 07-27-2023, 07:49 AM
Last Post: dstallmo
  PBP blank screen after updating Manjaro Franko 6 7,972 04-01-2023, 07:55 AM
Last Post: hacknix
  manjoro, it turns off when I close the lid River 2 3,378 12-12-2022, 12:13 AM
Last Post: River
Question Pinebook Pro shows only bright white screen when powered on Sean Whitton 3 5,548 07-22-2022, 01:19 PM
  Ring around screen following update tylerjohnson3208 2 5,464 05-10-2022, 01:52 AM
Last Post: diyagabriel
  Looking for Screen LCD Panel for the Pinebook Pro gerstavros 3 6,397 05-09-2022, 05:53 AM
Last Post: gerstavros
  Putting my screen on TV S265 6 9,934 10-07-2021, 08:00 PM
Last Post: ajawadmahmoud
  Screen refresh delay with kernel errors shawnanastasio 31 62,194 04-27-2021, 02:57 AM
Last Post: james64
