pinebook pro trackpad randomly stops working
Running Manjaro ARM i3-edition on my PineBook Pro. Just received the device a few days ago.
At first I noticed that the trackpad's palm rejection wasn't quite there, but then I noticed that it was suddenly great -- not just palm rejection, but finger rejection, button press rejection -- it stopped working altogether!
Well, I run i3wm, so I don't use the mouse all that much. I just kept trucking on the terminal, and then the cursor started randomly moving around again according to the movement of my palms as I typed.
So, the trackpad seems to randomly cut in and out every few seconds -- BUT! I can keep the touchpad "alive" if I constantly mouse around in little circles. But sometimes I have to wait for a while for it to come back once it goes to "sleep."
Any ideas?? I saw a post about touchpad drivers, but the 2021 units are supposed to be pre-updated.
Just to re-iterate, the trackpad is completely dead every few seconds. Not only non-responsive to touch, but also to physical clicks with the trackpad buttons.
You could try a different operating system on micro SD to eliminate the OS and it's "firmware".
(05-07-2021, 12:39 AM)KC9UDX Wrote: You could try a different operating system on micro SD to eliminate the OS and it's "firmware".
Actually, I figured it out this morning. Super simple. The powersaving mode for the keyboard USB device was shutting off power to the trackpad.
I changed the parameter in `powertop`, and bingo! it was fine. Wink
Palm rejection still kinda sucks, but I guess I can live with that Big Grin
Please put that in the wiki, if you can.
(08-06-2021, 02:30 PM)bikerlatt1 Wrote: Hey all is there a final word on whether or not the trackpad issues can be fixed through software or is this a permanent issue with the hardware that cannot be fixed? It might sound like I'm complaining but just looking for a answer as to if I should wait for a fix or go ahead and mod in a USB trackpad to replace the one onboard.
Have you seen this thread? https://forum.pine64.org/showthread.php?tid=14531
The new update definitely did it for me. It's not 100% perfect, but it's good enough that I don't have to use the old python touchpad hack script that someone kindly wrote a while back.
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 4 1,098 05-06-2024, 09:27 AM
  Pinebook Pro on Debian 12 Power Issue u974615 1 470 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 414 02-17-2024, 07:06 PM
  New Working nVME gilwood 0 332 02-12-2024, 08:46 AM
Last Post: gilwood
  Pinebook Pro charging issues tomekdev 1 747 01-05-2024, 08:40 PM
Last Post: tomekdev
  Replacement battery for PineBook Pro DrYak 3 1,295 11-07-2023, 10:09 AM
Last Post: DrYak
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 134,081 09-13-2023, 03:43 AM
Last Post: k3dAR
  PineBook Pro dead ottahe 9 6,314 01-18-2023, 07:41 PM
Last Post: ottahe
  Pinebook Pro malfunctioned hardware samtux 10 4,715 12-27-2022, 03:31 PM
Last Post: samtux
  PineBook Pro revision 2.2: Wishlist for the hardware issue fixes dsimic 115 141,122 11-30-2022, 04:28 PM
